    Extraction failed file is corrupt
    6 Posts 2 Posters 9.7k Views 2 Watching
    • holmes1977H Offline
      holmes1977
      hi all
      Just tried to download the lastest update (SU 7.1)
      The file downloads ok, but when I go to run it. The install fails, and says Extraction failed file is corrupt
      After some research on the net. I decided to try and use firefox instead of Win Explorer to download the file. I didnt have firefox installed on this computer. So I downloaded it, pressed run and the same message pops up.
      Has anyone else had the same problem. 😞
      Exaggeration makes a dull story better.
      • AndrewSA Offline
        AndrewS
        @holmes1977 said:
        hi all
        Jonathan,
        The SketchUp installer is a self-extracting executable. It has a small amount of built-in checking to prove whether the extraction is completed properly. If it says there was a problem, that means during the process of downloading, some of the bits being sent from Google's download servers to your machine became corrupted. The only thing you can do is download it again from scratch and see if you have better luck the next time.
        One option for ensuring the file is OK is to check its MD5 hash. If someone authoritative tells you what the MD5 should be, then you can run a program that performs a mathematical check on the file and produces a hash as output, which you can compare to the value you expect. If the value matches, your file is good. If the value does not match, you need to delete the download and try again.
        I expect you're downloading Google SketchUp Pro 7.1 for Windows:
        http://dl.google.com/sketchup/GoogleSketchUpProWEN.exe
        The MD5 hash for that file is:
        6cae8b7bcd469936273d3bd8d58cbf1d
        If you get a free MD5 checker for Windows, you can run it on the file you download and see if you get the same string as above. If not, your file is corrupted and you need to re-download.
        I've never tried the following MD5 programs, but they both look reasonable:
        http://www.softpedia.com/get/System/File-Management/MD5-Checker.shtml
        http://www.softpedia.com/get/Security/Security-Related/WinMD5Free.shtml
        I hope this helps.
        Andrew S.
        SketchUp Release Engineer
          holmes1977
          Thanks Andrew for the very well explained reply. πŸ‘
          You are right the MD5 hash is different
          I downloaded the MD5 Check Utility. After checking the file I found out that the
          MD5 hash is 42212ADAFD3330BD4A5AFD5B812CCED3
          which is different from 6cae8b7bcd469936273d3bd8d58cbf1d
          Ive tried downloading it again and again but keep getting the same results. Ive also tried 2 other computers on our network and get the same result. My next step is to try and download it from another location. then transport it back to my computer via usb stick. Hope that works. Just got a large job to do, which the update would help out truck loads.
          I'll post back with the results.
          • AndrewSA Offline
            AndrewS
            Although tedious, I think your plan is a good one. You need to make sure you're able to download the file error-free and in its entirety before you're going to be able to install it. Using the MD5 hash is more reliable than relying on the self-extractor's built-in check, too, so I do believe you're on the right track.
            I'll look forward to hearing how it goes.
            Andrew
            Andrew S.
              holmes1977
              Ok this is really confussing.
              I got my partner to click the link http://dl.google.com/sketchup/GoogleSketchUpProWEN.exe
              and download SU7.1 from her work computer.
              To test it, I got her to make a copy and paste it into another file. She then double clicked on the downloaded file. It ran then came up with the same message. Extraction failed file is corrupt
              Is there any other way to get hold of the SU7.1 upgrade. πŸ˜•
              HELP
                holmes1977
                Ok Im an idoit
                I didnt turn off AVG and Win fire wall.
                After that it downloaded fine.
