Strange!
I remember Susan (sorgesu) reporting a similar bug at the end(ish) last year. I don't know what happened to the bug report however.
Sorry for off-topic, but would you be so kind and tell me what plugins are those I highlighted with red in the print-screen and if possible to put links for them ?
Thank you!
Thank you!http://forums.sketchucation.com/viewtopic.php?f=180&t=20233&st=0&sk=t&sd=a&hilit=align+plugin
http://forums.sketchucation.com/viewtopic.php?f=180&t=17396&hilit=plugin
Thank you very much, dedmin! But there is one more in rop-right. And as I can figure out from icon, it makes faces perpendicular on a line. This one could be very useful for me, because right now I do this in a very hard and time consuming way.
See again
I found a way - just open the component for editing and then draw the guides inside that component, close it and then paste
