    .skp -> JSON -> .skp
    scheduled pinned locked moved Developers' Forum
    6 Posts 5 Posters 3.0k Views 5 Watching
    loading-more-posts
    • oldest-to-newest
    • newest-to-oldest
    • most-votes
    reply
    • reply-as-topic
    guest-login-reply
    deleted-message
      MartinRinehart
      I want to write a .skp -> JSON Ruby, and then, of course, JSON -> .skp.
      Possible? How much of .skp is accessible? What will I be losing?
      Second, has anyone explored the various ways of building the .skp? How does adding four edges compare to adding a face, given four corners?
      one-reply-to-this-post last-reply-time reply quote 0
        You want to take all entities apart into JSON values?
        What comes to mind is faces with holes need special attention. Arcs, Curves.
        Dimensions are a problem - as there is no Ruby access. As well as 3d polylines.
        DC's and their attribute dictionary? Or even any attribute dictionary. V-Ray for Sketchup for instance adds it's data in binary format.
        Textures - Projected property of textures aren't accessible.
          cjthompson
          you should definitely add the faces by points instead of by edges, because edges are entities, so if you export to a model that doesn't already have those entities, you will get an error.
          I haven't worked with JSON at all, so I don't know how much help I can be.
            Jim
            A .skp is binary file. I'm not sure I understand the question. Do you mean you want to export a model's geometry as a JSON string?
              MartinRinehart
              Exactly. The model is an object. Each collection is an array of objects. Each object in a collection has a type and an appropriate set of values, and so on.
              { entities:[{type:edge, ends:[{type:point3d, start:[r1,g1,b1], ... }], ... }] }
              • tbdT Offline
                tbd
                worked some time ago on a model2xml and it worked pretty well by extending each class with a to_xml so it was quickly implemented.
                this can be implemented in the same manner but as thomthom it is not possible to have a 100% dump and then reimport it back to SketchUp and have the same model 😞
                http://plugins.ro
                • first-post
                  last-post
