    Inputbox dropdown is not scrollable
    3 Posts 2 Posters 308 Views 2 Watching
      Pout
      I have an dropdown inputbox in Sketchup which contains a lot of values.
      It is created like this:
      list=_readable_milestones.join("|") dropdown=[list] prompts=["Milestones: "] #set the initial value in the dropdown list to the first date values=[_readable_milestones[0]] #show the selection window results= UI.inputbox prompts, values, dropdown, "Select a Milestone"
      The problem is that the dropdown box does not show an arrow or anything so i can scroll in it.
      Is this a common problem or is there somthing wrong with my script?
      regards
      • TIGT Online
        It's a limitation of the inputbox. Either split the 'Milestones' into sub-sections that can all be seen OR if you know what the name of the 'Milestone' is then select in the dialog's option window and type the first letter of its name, then use the up/down arrow keys to navigate to it and hit enter to use it...
        Alternatively use a webdialog - but that's another story... πŸ˜‰
          Pout
          Owkee, thx.
          That's the path i'll take
