    Twilight Render is Out
    extensions
    74 Posts 28 Posters 18.3k Views 28 Watching
      I posted an interview with Fletch in The Daily CatchUp. Quite interesting especially at the end where he is talking about development and plans for further features (most of what can be read about on the Twilight Forums of course but for the lazy, "this will do", too)
      • E Offline
        Ecuadorian
        My favorite thing of the interview is that they seem to be very open to user input... and that one of the two guys behind this is an architect himself.
        -Miguel Lescano
        • FletchF Offline
          Fletch
          Thanks guys, we are confident if people will try it, they will like it. 😄
          There are many video tutorials and a good user manual. For users that are intermediate or advanced in SketchUp who try it, in 30mins or less you will be rendering with Twilight.
          Fletch
            sepo
            Hey Fletch ...what is the score with Rovinj? Don't tell me you are Croatian? 😄
              Haha...
              He's just living there for a change. Not a bad choice IMO (once I kick off in a business and don't have to work for a living any longer, I might also move to the Istria - or Dalmatia somewhere)
                sepo
                It is an excellent choice. Istria is beautiful part of Croatia. Close to Italy ,Slovenia and Austria....very good choice. 👍
                • FletchF Offline
                  Fletch
                  Hi Sepo,
                  It's simple, my wife grew up here. 😄
                  We lived in Milwaukee for 8 years, now it's "her turn"... we'll see how it goes here.
                  The up-side is that if you love spearfishing (which I do) it's great place to live. 😄
                  Fletch
                    sepo
                    Good luck Fletch. It is lovely there. Good place for sailing as well. Also close to Austria and Slovenia for skiing. I think you will find that you will want to stay.
                    • FletchF Offline
                      Fletch
                      Being from Montana, skiing is my first love before spearfishing... so I will definitely check it out 👍
                      Fletch
                        kwistenbiebel
                        Don't know about spearfishing ( 😉 ) but I just tried the Twilight demo and I must say: fabulous User Interface!!!!
                        I wasn't expecting such a nice workflow. It is simple yet elaborate.
                        Some great thinking behind it.
                        I especially like the render settings screen and most of all the simple material setup. Just clicking the mat in the viewport with the mat sampler and the mat editor shows up. Great stuff.
                        Also the tool hints that appear when hovering above are life savers. Features of Kerkythea that I never understood actually make more sense now 😄.
                        I am happy to see that the real time tone mapper is there and working well.
                        Could the Twilight developers make a similar UI for Vray,Fry and Maxwell please? 😄
                        And a little question while I am here: Is it possible to acces the render settings .xml file ?
                        Also, if I want to use unbiased animation (path tracing progressive), can I assign a maximum render time per frame? the default of 100 or 500 passes seems overkill for some scenes.
                        A quick try:
                          Animation with progressive presets would indeed sound interesting.
                            kwistenbiebel
                            Hi Gaieus,
                            the progressive presets are in place. It is just that I can't change parameters.
                            An issue I am running into:
                            I am trying to render an animation, but each frame is rendered with the same (initial) view.
                            After each frame, the SU screen seems to go to the next frame (I see it moving), but the rendered view remains always the same?
                            [EDIT]: apparently the camera tab needs to be set to <Current View> in order to pick up the cam movement. Yeah!
                              That's exactly the issue I ran into (I thought I was going nuts already) and Chris finally told me the same solution.
                              • E Offline
                                Ecuadorian
                                The render settings .xml files are saved here:
                                C:\Program Files\Google\Google SketchUp 7\Plugins\Twilight\RenderSettings
                                To change the number of passes in unbiased animation presets, just look for this line near the beginning of the .xml file you want to edit and change the value:
                                <Parameter Name="Max Iterations" Type="Integer" Value="500"/>
                                -Miguel Lescano
                                  kwistenbiebel
                                  Thanks Miguel.
                                  I tried animation using a medium Photon Map setting and it is quite fast.
                                  • FletchF Offline
                                    Fletch
                                    ...I just tried the Twilight demo and I must say: fabulous User Interface!!!!
                                    Hi Kwistenbiebel,
                                    😄 This is a high compliment, indeed, we are pleased that you can appreciate it.
                                    This project has more than a year of very hard work/labor of love from a few guys from Kerkythea.
                                    We designed it with architectural designers using SketchUp in mind so that ANYONE, newbie to rendering, or advanced users like ourselves to be able to get out of it what we each want... that is, Twilight Render is as shallow or (almost as) deep of a program as you want it to be...
                                    Please use it in good health.
                                    Render Happy,
                                    Fletch
                                    • EdsonE Offline
                                      Edson
                                      fletch and kim,
                                      do you have any idea as to when a twilight mac version will be available?
                                      http://www.mahfuz.arq.br
                                      • FrederikF Offline
                                        Frederik
                                        The best answer I can give you is the following...
                                        @chris said:
                                        Porting the code to Mac is turning out to be more difficult than expected. 99.9% of the code is cross platform, yet there are so many little difference when building software on a Mac that the term "cross platform" is just a mean little joke. However, it is being actively pursued. But I can't give any dates because it's all new territory for me. 😳
                                        I can add that Chris is working hard on it...
                                        Cheers
                                        Kim Frederik
                                        • EdsonE Offline
                                          Edson
                                          thanks, kim.
                                          • U Offline
                                            urs0815
                                            ... the mac release for x-mas.... would be the right present 🎉
                                            • 3 / 4
