    Indigo Renders...
    27 Posts 15 Posters 4.1k Views 15 Watching
    • E Offline
      Ecuadorian
      Within my limited knowledge, this is what I understand:
      All currently available render methods take shortcuts, as they don't simulate light's interaction with every single subatomic particle and physical force present in your scene. They are all physical/mathematical models, or approximations to reality. The difference between "biased" and "unbiased" methods is that the "unbiased" ones use a more-or-less brute-force approach, meaning that they interpolate nothing, while the "biased" ones do interpolate some values to arrive to a quicker, but less accurate, solution.
      Biased methods could be compared to a map of voting trends by cities based on an "Exit-poll", while Unbiased ones could be compared to another map based on actually counting vote by vote in successive random passes over the whole country.
      And of course, I want both methods for different situations 👍
      -Miguel Lescano
      • N Offline
        notareal
        @notareal said:
        If you are interested about bias in rendering, I suggest reading this http://www.cgafaq.info/wiki/Monte_Carlo_Bias
        ^ explains biased and unbiased. Did you know, even unbiased renderer can fail - make a tiny hole in a wall and see if light comes trough.
          remus
          Technically it wouldnt fail, it would just take a very long time to complete.
          • N Offline
            notareal
            Not that it really matters, but it will fail if hole is small enough. Stopping criterion will come to play. Just try it out with your favorite renderer. Two rooms and a microscopic hole in a wall between them. Lightsource in the other room and camera at the other.
              Dennis_n
              thank you so much people, an awesome lecture
              • W Offline
                Whaat
                I've been doing some renderings of the house that we are currently building. I'm pretty happy with this one except that I wish I had taken the time to model the seams of the furniture.
                • dermotcollD Offline
                  dermotcoll
                  Dale that is simply wonderful imho - I really like the whole ambiance of the image and would not fret too much about the seams on the furniture. Really good. 👍
                  When you burn your arse - you gotta sit on the blisters!!
                  • 2 / 2
