    Sketchup preset for the NVIDIA Quadro 1700
    11 Posts 7 Posters 4.5k Views 7 Watching
    • sketch3d.deS
      sketch3d.de
      @pep75 said:
      Does anyone have a good preset for a Quadro 1700 card that I can load into the NVIDIA control.
      do not change the OpenGL default settings (e.g. "let the application decide..") which are already fine for SU, do not increase anti-aliasing which might slow down OGL output speed.
      @pep75 said:
      I'm not so satisfied about the card ...
      what exactly is the problem?
      use the latest driver for your os, if using a desktop system with Win x32 the recent driver revision is 190.38 from 23.07.09:
      Invalid URL
      (www.nvidia.com)
      hth,
      Norbert
      • AnssiA
        Anssi
        Norbert's advice is as good as it gets. I tested the same card in XP64 with a driver published in early June with no problems.
        Anssi
        • pep75P
          pep75
          ...sorry that my reply took so long...but anyway thanks for the replies!!
          I had a Nvidia 8800GTS 32OmB card and sold it to buy myself a "professional" graphic card with sufficient memory on it. The card costed 500,- euros and a 8800 gts costed 150,-. And well I can hardly see the difference between these two really. OK, the Quadro card is slighty faster, but I'm really not stunned.
          I'm working on a 64bit platform (windows 7),8gb memory, the processor is a 6600 quadcore and my hardisk is a 80gb Intel X25 ssd. Cinema4d is going like a razor but Sketchup feels like sluggish....
          grtzzz
          Pep
          • F
            FoXar
            A shame, it's due the bad engine SU has, nothing to do about that, even not a Quadro.
            The only way you'll notice difference is with the more advanced 3D apps out there, as you mentioned, C4D.
            Cheers,
            FoXar ^^
            • sketch3d.deS
              sketch3d.de
              video memory is typically no issue, at least using a video card w/ 256/512mb on board (not shared w/ the OS). More memory does not improve the output speed in any way and thus is not recommendable besides other apps as e.g. raytracing programs can make use of it
              the Quadro FX series provides an improved maturity and stability for the OpenGL based 3D output mainly for mid-range/high-end CAx apps and the driver optimizations available for them. The speed in connection w/ mesh-based 'standard' modelers as e.g. SU or Raytracing apps will normally not profit by using a Quadro FX, actually a GeForce in the same price range is often faster because of using a more recent GPU.
              C4D is multi-threaded, SU currently not. Which is understandable because slicing a render task generating raster data (i.e. pixels) is much easier than distributing vector based modeling operations over several kernels.
              The only way to improve the performance of SU is to use a faster CPU in the sense of speed of one (1) kernel, i.e. a faster dual core is better than a slower quad core... currently.
              hth,
              Norbert
              • TaffGochT
                TaffGoch
                @pep75 said:
                Does anyone have a good preset for a Quadro 1700 card that I can load into the NVIDIA control. I'm not so satisfied about the card and I wonder if this is a software issue(setting) or a hardware issue.
                Pep,
                I have the Quadro FX 1500M, and use the nVidia-customized driver. The SketchUp developers and nVidia partnered together to produce the customized settings. This screen grab is of the nVidia control panel, outside of SketchUp:
                I noticed improved speed, and correction of anti-aliasing and backface-shading issues.
                I don't know if the 1700 uses the same driver, but its control panel should allow you to customize the settings yourself, following the settings depicted in the above image.
                Taff
                SketchUp Pro / Version 6.4.112
                SketchUp Pro / Version 7.0.8657
                Windows XP Pro / SP3
                DELL Precision M90 / 2 GB RAM
                nVidia Quadro FX 1500M / 256 MB
                nVidia driver: Forceware 169.96
                "Information is not knowledge." -- Albert Einstein
                  JGA
                  TaffGoch,
                  Thanks, I'll have to give this a try.
                  Regards,
                  JGA
                  • pep75P
                    pep75
                    THANKS to you all!!!
                    And by the way it's true what Norbert said...My ikd crappy P4 3.0 ghz is faster then my quadcore!
                    • GaieusG
                      When I bought my new PC, I kept this in mind and it now has a dual core at 3.0 GHz (could be clocked up to something like 3.8 but haven't tried yet).
                      Now of course it is a kind of "compromise" only because if I were to render more, more cores would definitely be useful but I rather model than render (plus ultimately many "modern" renderers can do network rendering as well so I can even hook some old machines together to do that when it comes to that).
                      • AnssiA
                        Anssi
                        As to processors, the newer Xeon and i7 processors seem to have a slight edge compared to older dual- and quadcores. I tested a 2.53 GHz Xeon a couple of months ago, and it seemed equal or a bit faster with my small models than a 3.6.GHz P IV.
                        Anssi
