    Subdivide and smooth missing right click options..
    5 Posts 2 Posters 635 Views 2 Watching
    • marked001M
      marked001
      I'm specifically looking for the 'force update' option.. i'm opening the object, and right clicking...and dont see any extra menu items.... what am i doing wrong? thanks!
      http://www.revision21vis.com
      instagram: revi21on
      • W
        Whaat
        Are you trying to this on a group that you 'cut and paste'? Also, it won't work if you copied the proxy. It will only work on the original proxy.
        Can you re-create the proxy by selecting the group and running SDS again?
        • marked001M
          marked001
          ah yeah, it might just be a copy... that is probably what it is. I can run SDS again, but I've got another copy that I've cut pieces out of, and re-running SDS will make these go away.
          if i pull one out of the components menu, will that count as an original?
          thanks for the help, Dale...this plugin has really transformed sketchup.
          instagram: revi21on
          • W
            Whaat
            Save your file before you try this:
            I think the best way is to explode the proxy, regroup, and apply SDS again. Then, it shouldn't mess up any of your other copies.
            • marked001M
              marked001
              right...that'd work... i'll just be more careful next time and keep the original safe and sound... first time really using the plugin for a project. thanks for the help.
              instagram: revi21on
