Subdivide and smooth missing right click options..
I'm specifically looking for the 'force update' option.. i'm opening the object, and right clicking...and dont see any extra menu items.... what am i doing wrong? thanks!
Are you trying to this on a group that you 'cut and paste'? Also, it won't work if you copied the proxy. It will only work on the original proxy.
Can you re-create the proxy by selecting the group and running SDS again?
ah yeah, it might just be a copy... that is probably what it is. I can run SDS again, but I've got another copy that I've cut pieces out of, and re-running SDS will make these go away.
if i pull one out of the components menu, will that count as an original?
thanks for the help, Dale...this plugin has really transformed sketchup.
Save your file before you try this:
I think the best way is to explode the proxy, regroup, and apply SDS again. Then, it shouldn't mess up any of your other copies. -
right...that'd work... i'll just be more careful next time and keep the original safe and sound... first time really using the plugin for a project. thanks for the help.
