    South wind #2
    51 Posts 15 Posters 7.5k Views 15 Watching
    • michaliszissiouM Offline
      michaliszissiou
      September in Greece. Time for fishing squids.
      Just playing with zbrush. Then this simple scene came in my mind. Baked in blender > rendered with podium. Used my old sea texture, the first I made. Just some PP in gimp, my usual way to adapt the SU fog effect, sea birds, vignette effect. Thats all. Rendered in 40 sec. Full quality noisy presets.
      • boofredlayB Offline
        boofredlay
        That is beautiful. Is Zbrush easy to learn?
          sepo
          Great atmo....beautiful.
            michaliszissiou
            Thanks sepo and Boofredlay.
            About zbrush, the best thing ever happened to me in my sort 3d story lol. If its easy to learn? asdasdfvbxcvbdttymmvb, does this help?
            But if you need help, here I am. These guys make this app better and better. And of course out of any logic you can imagine. The model is called tool (!), there's no save (!), you must invert UVs vertically before exporting (!), things like this. Please don't expect something like SU, blender, 3dMAX, maya, xsi, modo, etc.
            • soloS Offline
              Michalis, as you can see I got your model.
              I blended the texture adding erosion banding and a marine rock texture, I then used an ocean node to create a foamy choppy sea with 2-5 ft wave displacement, threw in a few low poly SU birds and hazy morning spectral atmosphere. Original render is 1600x600, rendered in 4 mins.
              No post work at all, straight Vue render.
              http://img168.imageshack.us/img168/5540/michalisrock1000.jpg
              • FrederikF Offline
                Frederik
                Looks beautiful...! ๐Ÿ‘
                Could be fun to have the model enabling others to give it a go with their favourite render application... ๐Ÿ˜‰
                Cheers
                Kim Frederik
                • N Offline
                  notareal
                  Looks great! Vue atmosphere is hard to beat. Loved to have the scene in my hands too...
                  Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                    michaliszissiou
                    This is impressive. This orison is fantastic. Realistic. The sea!
                    Displacement at sea is really convincing too.
                    I know pete that you are a kind of magician, but I really need this kind of software , VUE. See how orison looks like. Impressive!.
                    Thanks for all your kind comments here. If someone wants my SU doc should pm to me, so having the email, can post the 9 mb SU doc. Good luck. Have in mind that this doc is rendered in podium in 40 sec (full quality). )
                    Less is more. (sometimes)
                    • soloS Offline
                      Michalis, if you don't mind sharing the rock I can reduce it and post here, maintaining the mesh but just reducing the image without loss of detail.
                        michaliszissiou
                        Thanks pete. But what about the UV texture? I tried too and all came to a very smooth mess, nothing like what I was expecting. Rocks seem to be an easy model but it's not like this. I'm trying to model low-polys convincing rock models but haven't found it yet.
                        • soloS Offline
                          Michalis, try this texture, it's reduced from 12MB .bmp to 181kb .jpg I kept the size, so you can replace the original with this and it will stay mapped.
                            mirjman
                            texturing on that first render is great.. you can really see where the rock interacted with the water, however the water seems to ignore the rock in both renders!! gives it the impression of a floating rock
                              michaliszissiou
                              this is for mirjman: thanks for these kind comments. IMO you need to spend some more time near sea. These sea rocks are really floating most of the time. Even whole islands are floating. Even Feidias's statues are floating. Today greek politicians and economists are floating too. ๐Ÿ˜†
                              for solo: Pete, there's something I don't understand. I could use jpg too, but SU doc seems to have the same size. What exactly happens there? Even so, we should never use jpg for textures, not really a good choice.
                              For everybody who doesn't know what a baked model is, please have a look in this UV map. It seems rendered already.
                              • soloS Offline
                                The rock was screaming for a tropical make-over.
                                All Vue, no post processing.
                                Added two species palm ecosystem, texture of rock is as per above reduced map.
                                Tropical water, slight wave algorithm, buoy is an old SU model of mine.
                                http://img127.imageshack.us/img127/9351/tropicalrock.jpg
                                  Hum hum : Menu Tool/Save as ๐Ÿ˜‰
                                  Cool seatime images! ๐Ÿ˜Ž
                                    michaliszissiou
                                    For Pilou: Do you know how to use zbrush? I paid 600$ for this and I know how to use it. I also have some posts in zbrush forum but you already know this.
                                    Pourquoi tu n'arrรชtes pas cette habitude, Pilou? C'est la deuxiรจme fois que tu fais la mรชme chose ร  mes "posts".
                                    For solo: So you don't need my textured model, just a cone. lol. Nothing to do with September in greek islands, anyway a great render, and I particularly like this model (I don't know how to spell this in english) I've admired in your site. I really had this in mind thinking about a sea scene.
                                      Sorry for the misunstanding ๐Ÿ˜ณ
                                      And I have edited the previous one
                                      Don't want any polemics ๐Ÿ˜„
                                        michaliszissiou
                                        I'm proud just for one thing here. Rock model under 1000 polys. Unfortunately looks rather soft. But it gonna be the base of a lighthouse, so...
                                        Podium render in 20 sec, full quality noisy preset (one reason to love baked models). Just a little PP for SU fog effect.
                                        • david57D Offline
                                          david57
                                          Looks professional.
                                            michaliszissiou
                                            Thanks david. I post this too so have an idea what's happening with a low polys model + a render engine that doesn't support displacement maps or even normal maps. Rendered in zbrush internal renderer in 10 sec, 2 000 000 polys here.
                                            • 1 / 3
