    Indigo Renders...
    27 Posts 15 Posters 4.1k Views 15 Watching
    • soloS Offline
      Whoah Dale!!
      What kung-fu are you using? These are amazing.
      Is this the commercial version? now for the question that many may wonder....how long did they take?
      • W Offline
        Whaat
        @solo said:
        Whoah Dale!!
        The commercial version is identical to the free version. There is just a resolution limit of 0.7 megapixels and a watermark in the lower right corner.
        The ocean horizon render and the caustics render took about 3 hours on one thread over a mediocre computer. The others took about 8 hours. Indigo supports unlimited processors and has great network rendering support to quicken the pace.
        Still, it is not fair to compare these times to other unbiased render engines because scene setup time is blazing fast. A total Indigo newbie could set up these scenes for rendering in anywhere from 1-5 minutes. The time savings for setting up materials and lighting makes up for the render times. With Indigo, you don't need to spend 6 hours doing test renders and tweaking to make sure you have all your settings corrrect. You just click the render button and let it cook!
          remon_v
          really nice like them all
          • W Offline
            Whaat
            Duh! 😳 Loaded it up and it stalls while collecting mesh. I guess I shuld have uninstalled the last version??
            You need the latest versions of Indigo and SkIndigo (2.0.12). Install Indigo first, then SkIndigo. Did you try to run Indigo 2.0.12 with an old version of SkIndigo? It may not be compatible.
              I try to keep up with the Indohgo news as much as possible
              http://news.sketchucation.com/?s=indigo
              but indeed, these renders are really great, thanks Dale 👍
              • StinkieS Offline
                Stinkie
                The man's right. 😎 SkIndigo is da bomb! (Do young people still talk this way?)
                  remus
                  All the time. You should try it on the local youths, im sure it'll go down well.
                  Back on topic, very nice whaat 👍 Particularly liking the sea shot, i'll have to steal your shader for that and give it a go at some point.
                    redot
                    The last two are fantastic Dal
                    Nice work.
                      kwistenbiebel
                      Nice work Whaat!
                      I wish we had an endless budget in our office to spend on Render engines. unfortunately we haven't.
                      Will be trying the demo for sure though.
                      • charly2008C Offline
                        charly2008
                        Last night, I have downloaded and tried the INDIGO renderer. I used the standard settings for the scene below.The Time required for this scene was amazing, about 1.5 hours.
                        Then I rendered the same scene with Kerkythea with the preset no.3 (PhotonMap-Quick). The Time required for this scene was about 5 Minutes. Below you can compare the results.
                        Karlheinz
                        • StinkieS Offline
                          Stinkie
                          I'm sure if you chose one of KT's unbiased presets, you'd find that the render time would go up significantly. There's little point in comparing a biased render method with an unbiased one.
                            charly2008
                            Hi stinkie,
                            i'm just a beginner in rendering Techniques. Maybe you can give me some advice what settings I should choose in indigo to get a similar result in a few minutes with Indigo?
                            Karlheinz
                              remus
                              You cant. The render method used in indigo will always take a long time, as it applies a brute force approach which although accurate takes a long time.
                              This is in comparison to some of the presets in kerkythea which 'fake it' to give you a much faster render, but one that cant reproduce real life effects as accurately as indigo.
                              Thats what stinkie meant when he said its pointless comparing unbiased (indigo) renderers and biased (kerkythea, sort of) renderers.
                                charly2008
                                Hi Remus,
                                thanks for your explanation
                                Karlheinz
                                • N Offline
                                  notareal
                                  If you are interested about bias in rendering, I suggest reading this http://www.cgafaq.info/wiki/Monte_Carlo_Bias
                                    benindigo
                                    Basically unbiased means no approximations, so slower but more accurate. The hardest part of writing an unbiased renderer is making it happen fast. 😄
                                    [floatl:1uor9jcm]Indigo Renderer for SketchUp - Photorealistic rendering for SketchUp[/floatl:1uor9jcm]
                                      benindigo
                                      @charly2008 said:
                                      Karlheinz
                                      These kind of scenes don't really show the speed of Indigo. You want to compare two interior scenes that are purely lit by sunlight. And include the set-up time of each renderer. Indigo might win that race. ;D
                                        Dennis_n
                                        I was a bit out of the loop on the renderers, what is a difference between biased and not biased render?
                                          remus
                                          Unbiased means the renderer models light in a realistic fashion, so you render is made by shooting rays around your scene and modelling precisely how they interact with the materials in your scene.
                                          Biased renderers dont necessarily stick religiously to an accurate model of light, so they can make good guesses at how light behaves to speed up the rendering process as much as possible. The downside to this is that you dont always get an accurate render out the end, and some effects (such as caustics) can be more difficult to reproduce.
                                          • E Offline
                                            Ecuadorian
                                            Within my limited knowledge, this is what I understand:
                                            All currently available render methods take shortcuts, as they don't simulate light's interaction with every single subatomic particle and physical force present in your scene. They are all physical/mathematical models, or approximations to reality. The difference between "biased" and "unbiased" methods is that the "unbiased" ones use a more-or-less brute-force approach, meaning that they interpolate nothing, while the "biased" ones do interpolate some values to arrive to a quicker, but less accurate, solution.
                                            Biased methods could be compared to a map of voting trends by cities based on an "Exit-poll", while Unbiased ones could be compared to another map based on actually counting vote by vote in successive random passes over the whole country.
                                            And of course, I want both methods for different situations 👍
                                            -Miguel Lescano
