    Pausing for Sketchup to update
    11 Posts 5 Posters 1.7k Views 5 Watching
    • Chris FullmerC
      Hi Mike, to undesratnd better, you say you are trying to make tour through your model. Do you want ruby to move the camera through the model from object to object, and so it will be a regular looking animation? Is that the goal?
      If so, you will need to make a camera and animate it, using the object locations to guide the location of the camera. I'm not sure exactly what you do to do that, but I think it is the animation class, and you just animate the camera.
      Is that sort of the right idea?
        designforlife
        Hi Chris, thanks for the reply and yes, I have got the camera to move without using the animation class or pages. So the step I can't solve is how to avoid the need for user intervention.
        I began with some code I found on the Google blog here: http://sketchupapi.blogspot.com/2008/11/storing-and-retrieving-with.html. This creates a simple group with attributes attached. The group is placed at the current view and takes the current camera parameters as its attributes. A context menu item allows you to go to that view with a few clicks.
        I use the reveal_view method to first set up the views I want but the go_to_view method is not convenient for viewing in a particular sequence - you may not be able to see the next location to click on it. An advantage of my idea is you can even hide the cameras or turn off the layer they are on so the model is not cluttered with camera groups.
        I also made a modified version of reveal_view so that I don't have to go to each location to create the camera for that view. With this version, a context menu becomes available when an edge is selected and its start and end point become the eye and target of the camera.
        Since these 'cameras' are all placed on their own layer, I can use layer.name=="cameras" to store them in an array. It should then be a simple matter of extracting the attributes from each in turn (with info=cam.attribute_dictionary("is_a_camera")) and sending the view to that location (with view.camera=Sketchup::Camera.new(info["eye"]...etc) but Ruby doesn't have the good grace to wait unless I use messageboxes, which is a bit self defeating.
        Anyway, here is my code:
        def do_tour
        	ents=Sketchup.active_model.entities
        	cams=[]
        	e=0
        	num=ents.length
        	while e < num
        		if ents[e].layer.name=="cameras"
        			cams.push(ents[e])
        		e+=1
        	cam_no=0
        	cam_indx=cams.length
        #	while cam_no<cam_indx
        	cams.each do |cam|
        		m=Sketchup.active_model
        		view=m.active_view
        		UI.start_timer(3, false) {puts cam_no, cam}
        		### For some reason this timer now does not pause, but it did previously. The view moves
        		### immediately to the last camera position and halts. It does verify in the console that
        		### the script is stepping through the camera group list. Only the last camera number is
        		### displayed (cam_indx times).  If the flag is set to true instead of false, you can see
        		### in the console it is looping endlessly but the view remains the same.
        		view.camera=Sketchup;;Camera.new(info["eye"],info["target"],info["up"],info["persp"],info["fov"]), 3
        		# UI.messagebox("camera no.; " + cam_no.to_s)   ### uncomment this line to see how the script
        								### (almost) should work.
        		 view.invalidate ### I read somewhere that if this is placed after the messagebox call, the
        				 ### box won't appear. But it does.
        		cam_no += 1
        ### I also tried the following snippet but it merely behaves like start_timer
        #		time_mark = ( Time.now + 3 )
        #		while time_mark > Time.now
        #		end
        This would be activated by a Plugin menu item.
        I've attached a Sketchup file with some cameras already created. It is not pretty but should save time for you.
        test_anim.skp
        If the problem is a simple bug or wrong syntax, it eludes me. My conceptual understanding of Ruby is weak (hence my wholesale copying of Google's code). But if I can get past this, I can think about different transition times, changing attributes (to pan maybe), and maybe allowing a user to pause whenever they want.
        Mike
        • T
          tomasz
          Mike,
          Check the SU2KT exporter. There is a class called 'AnimCamera' (now I realise I should have given it more unique name).
          class AnimCamera
          def initialize
          	@frame=0
          	@slide_time=0.0
          def nextFrame(view)
          	@slide_time=@frame/@frame_per_sec
          	model=Sketchup.active_model
          	model.pages.show_frame_at @slide_time
          	@frame+=1
          def stop
          	Sketchup;;set_status_text("", 1)
          	Sketchup;;set_status_text("", 2)
          end # class AnimCamera
          This way you can start an animation:
          Sketchup.active_model.active_view.animation = AnimCamera.new
          Check Ruby API for more info.
          Tomasz
          • chrisglasierC
            chrisglasier
            I have used a shuttle method in javascript that might be useful for you. I will try and explain it in javascript but I am sure it is easy to transpose into ruby. The idea is to shuttle from one function to another, but here I use a controller function.
            There is a global variable - pass.
            The controller function has this statement eval("fun"+pass)() in a timer like setInterval.
            Each fun+pass function has two parts - conditional stop and go (or wait in your case I guess).
            If the condition is satisfied, stop timer, pass++ and call controller .... and on and on.
            I hope this is helpful.
              designforlife
              ...so the answer is that I am barking up the wrong program tree? Damn! So near, yet so far.
              • chrisglasierC
                chrisglasier
                Not necessarily, but web dialogs are very good if you want flexibility and interoperability including human interaction. Why not give them a try?
                  designforlife
                  Could you explain a bit about web dialogs? How do they relate? I tried a few of the methods from the API page to display a web page in Sketchup. Beyond that, I am trying to imagine the potential.
                  Actually, the name initially suggested to me they might work the other way round - to display sketchup in a web page but I believe that requires the web user to download and install a browser add-on.
                  Mike
                  • Chris FullmerC
                    Hi Mike, sorry if I'm being dense, but to make sure I'm understanding....
                    The only thing you want is to make it so the user can pause/cancel the animation while the animation is in process? Is that the only thing that you are asking about?
                    • chrisglasierC
                      chrisglasier
                      Well you could have a look at this plugin and, as you have a PC, download it. The ruby file shows you how to open a web dialog window and sit an html file in it. You can also find how to pass strings back and forth between JavaScript and Ruby.
                      Let me know if you find this helpful but need more info.
                      Just saw your note Chris ... what I understood was that Mike wants to stop the script outrunning the animation, so I suggested using two functions, one substituting his messagebox suggestion.
                      cg
                      • K
                        kirill2008
                        Can anyone explain the correct use of view.invalidate and/or start_timer?
                        You may try to substitute "while...end" or "for...end" etc control structures by timer. The funny thing is that maybe it is not necessary to put 'Sketchup.active_model.active_view.invalidate' line inside the timer.
                        ` wait_time=(<suspend period>)
                        times=(how many times you want to repeat <some code>)
                        timer_id=UI.start_timer(wait_time,true) {
                        <some code> # put some geometry to active_model
                        times -=1 # decrement times to be able to stop timer
                        do not forget to stop timer
                        timer_id=UI.stop_timer timer_id if times==0
                        I noticed, that visual results of <some code> processing appears even without view.invalidate. Note, that <some code> appears to work a kind of 'transparent' way (you may zoom, pan, rotate view and even launch other commands during the timer processing).Such behaviour indicates, that during <suspend period> all possible events (mouse events, key stroke events and so on) rise and you can handle them.
                        Hope that helps.
