    Sketchup+VrayMax
    70 Posts 20 Posters 16.4k Views 20 Watching
    • N Offline
      nomeradona
      ok i will make a tutorial for this render how i approach this.
      • N Offline
        nomeradona
        1. Here is the original sketchup scene. I use the texture from form fonts for these pillows.
          On SU I group by materials. all the same materials are on one group.
        http://i334.photobucket.com/albums/m421/nomeradona_1234/1-2.jpg
        1. export to 3ds file with the attach settings how i export my files
        http://i334.photobucket.com/albums/m421/nomeradona_1234/2-2.jpg
          steelers05
          Awesome exlanation Nomer. I have one more question though, what happens of the scale of a new bitmap is different than the scale of the one you are replacing? How do you work with that? because many times I am asked to change from, for example, one brick to a completely different kind of brick and my original material images are different sizes with different repeats.
          • N Offline
            nomeradona
            1. be sure to create one seperate folder. as you can see on the image below all the materials that i used appears
            http://i334.photobucket.com/albums/m421/nomeradona_1234/3-2.jpg
            1. import to max
            http://i334.photobucket.com/albums/m421/nomeradona_1234/4-1.jpg
            • N Offline
              nomeradona
              1. link the folder where yur textures are, so that max can link them.
              http://i334.photobucket.com/albums/m421/nomeradona_1234/5-1.jpg
              1. once you link them try to render them you will see them already there.
              http://i334.photobucket.com/albums/m421/nomeradona_1234/6-1.jpg
              • N Offline
                nomeradona
                but i dont want to stop there. i want to create vray materials and tweak further their properties
                1. so create a new vray material and on the diffuse slot box load your texture which are located on the scene
                http://i334.photobucket.com/albums/m421/nomeradona_1234/7-1.jpg
                1. drag the material to the group.. here is the importance why you need to group them. you can find them easily in max.
                http://i334.photobucket.com/albums/m421/nomeradona_1234/8-1.jpg
                • N Offline
                  nomeradona
                  do not forget to preview them.. finally all you have to do is to repeat the steps and do it with the other materials. now you can add bumps, displacement etc. etc...
                  • N Offline
                    nomeradona
                    well that is easy adjust the UV tiling of the bitmap in max easily, if we are talking only here of the scale of a plane or face. but if you are talking about organic shapes then you need to remapped it. the preview window will help you see how the map will tile and apply to the face.
                    honestly there are a lot of workarounds here. you can resize the image perhaps in PS. or you could remap your texture in SU and export only that group. when you import it voila.. the same position. all you have to do now is to hide or erase the former group to the scene.
                    • N Offline
                      nomeradona
                      @michaliszissiou said:
                      The winner in painting the unwrap UVs is (IMO) zbrush.
                      i beleive you since you are mastering this soft now.
                        steelers05
                        awesome explanations nomer. Cant thank you enough. I figured the UV tiling would be the answer to scaling...I asked because I am not a huge fan of adjusting based on the UV tiling because there does not seem to be any real units that relate and it becomes a guessing game in a way. I guess I am used to the control you get in SU (suprised I am saying that considering how few options you have when it comes to mapping in SU). Thanks again for your work here...it will really help many people.
                        • N Offline
                          nomeradona
                          i am also not a huge fan of this guessing game UV tiling. that is why they develop the UVW unwrap modifier so you could map it as you wish.. but i do beleive from 3dmaxdesign2009, there is a new UV tiling where you can see the realscale. i will look on this more.
                          if you are use to with SU, then do the SU workaround... remap your chosen texture on the group you want to change. then select only that group and export it as 3ds same as above. in max, remove or hide the original group and import the new 3ds. you will find that when you import it the location is perfect. this is also what i do if i need so more component which i failed to do in the first imported file. i just add them in SU, group, and export them only.. without exporting the whole thing.
                          • N Offline
                            nomeradona
                            now there is this extension....
                              rv1974
                              Simplier way:http://www.scriptspot.com/3ds-max/vraymtlconverter-v2-5
                              • N Offline
                                nomeradona
                                wow i did not know that thaks dor pointing that rv1974 β˜€
                                • N Offline
                                  nomeradona
                                  @artysmedia said:
                                  Yeah, i use this method also! I's faster! πŸ˜„
                                  yeah,,, really big thanks i will use this..
                                  • artysmediaA Offline
                                    artysmedia
                                    Yeah, i use this method also! It's faster! πŸ˜„
                                    Working with: Win7 64 bit OS - Core i5 - 2,27GHz and 8GB RAM
                                    Blog: Artysmedia
                                    • N Offline
                                      nomeradona
                                      have written a small tutorial for my filipino friends about exporting 3d warehouse vehicles to max.
                                      http://cgpinoy.expressforum.org/vray-for-sketchup-tutorials-f97/nomeraadona-s-tutorial-exporting-3d-warehouse-vehicles-to-max-t6047.htm#124932
                                        robert111
                                        vray good rendering nomeradona
                                        thnaks for your tutorial to export sketchup to max
                                        but can you make another tutorial for vray max lighting et rendering plz
                                        show your setting for vray max light and setting for your vray max renderer
                                        thanks robert , i wait your reponse
                                        • N Offline
                                          nomeradona
                                          this is not really my niche my friend. but honestly my approach with max is the same as vraysketchup. just differnt terminology sometimes.
                                            robert111
                                            nomeradona
                                            thanks
                                            but when i export my su model to max
                                            i have problem with glass window i have back face outside ( backface in my outside for my windows )
                                            why to resolved this problem ( back face problem in max )
                                            thanks i wait your reponse bye
                                            • 3 / 4
