    Conventions for Output Code
    15 Posts 4 Posters 1.8k Views 4 Watching
      Anything related to webdialogs I make by the W3C specs. (Unless I need to do some tweaks to work around IE bugs.)
      It's the safest thing to ensure that everything works on multiple platforms, and for future versions.
        MartinRinehart
        <br> or <br />?
        Warning: that is a trick question.
        • Chris FullmerC
          <br />
          Hows it a trick Q? All my books and W3 standards I've read suggest that it should only be <br /> as all tugs must have a closing />.
            @chris fullmer said:
            <br />
            Only when you use XHTML. For plain vanilla HTML you shouldn't close it.
            I use XHTML as it allows simple XML parsers to traverse my documents and extract data.
              MartinRinehart
              <br />
              The HTML 5 spec deprecates <br /> in favor of good old <br>. The silly version was born with, and dies with, XHTML, the one and only HTML that tried to be XML.
              • GaieusG
                C'mon guys, decide which one I should use. I build (rather amateur) websites but would like to work correctly.
                πŸ˜‰
                  <br />
                  HTML5 comes in XHTML flavour as well. So <br /> still lives if you opt in for the XML version.
                    πŸ˜‰
                    If you use HTML then don't close empty tags, if you use XHTML then you have to close empty tags.
                      MartinRinehart
                      πŸ˜‰
                      All the major western browsers have been happy with <br> this century. If your doctype specifies "XHTML strict" you want "<br />". Otherwise the original is preferred.
                      According to Wikipedia, "HTML 5 is the next advancement of both HTML 4.01 and XHTML 1.0, as development on the next version of the latter has been ceased." (I think I'll go clean up that English.)
                        MartinRinehart
                        According to Wikipedia, "HTML 5 is the next advancement of both HTML 4.01 and XHTML 1.0, as development on the next version of the latter has stopped."
                          Wiki isn't quite accurate. XHTML 1.0 was meant as a transition towards XML based documents. But IE put a fork in that. One of the reasons XHTML 2.0 died.
                          This sums up XHTML5 vs HTML5 nicely.
                          http://html5doctor.com/html-5-xml-xhtml-5/
                          HTML5 also gives some flex to <br/> style tags due to its widespread use: http://www.w3.org/TR/html-design-principles/#pave-the-cowpaths
                            One step forwards, two steps back, one step sideways shuffling forwards.
                              MartinRinehart
                              For better or worse, the WHATwg decided that XML was a mistake. The current w3c spec (August) is the original, XML-free WHATwg spec. Lawson is about 2 months earlier than the current w3c spec. An earlier version deprecated <br />. It's not even mentioned in the current spec. The formerly dead form, <br clear=...> has been resurrected as "deprecated but must be implemented as follows: ..."
                              Seems like good thinking, but much forgotten between '07 and today. I'll bet this is followed in practice even if it isn't in the spec. Can you imagine an actual browser shipped without supporting <center>?
                              But we wander. Back to my original question. I propose the following convention:
                              As browsers are more predictable in standards mode than quirks mode, Ruby-generated HTML should include a doctype and should be valid for its doctype.
                                hm.. that's interesting. Haven't paid much attention to HTML5 the last few months.
                                But we wander. Back to my original question..
                                Ah, yea. The topic! πŸ˜„ Sorry, I often stray away and webdev is one of my major interests so I stray even quicker and further when that topic is even remotely related. 😳
                                Agree. Since webdialogs must run under the webkit engine and IE the best chance for platform compatibility is following the W3C standards.
                                When I make webdialogs I do the same as I do when I develop websites. I code to the standards, then to account for IE notoriously bad handling of the standards I add some conditional comments that adds CSS and JS fixes. Most of the time visual quirks in IE is by triggering hasLayout
                                For better legibility and re-usability, separate CSS and JS their own respective files.
                                Using HTML validators to detect correct markup is very important. Once a document is invalid there's no way to predict how the different rendering engines will recover and you can not expect cross platform compatibility.
                                I'm starting to realise that there hasn't been posted any recommendations of best practices when it comes to webdialogs. Coming from a webdesign background I haven't given it much thought.
