    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.6m Views 202 Watching
      Steelyjoe_n
      Hey, I've followed the quickcards installment guide but upon opening Sketchup it isn't running Tools On Surface, I'm not given any loading error or anything, it simply doesn't run, any help?
        Steelyjoe_n
        Nevermind
        I forgot to check it in preferences, thank you for the program anyway πŸ˜„)
        • N Offline
          niarfe
          Fredo!!! I'm becoming your biggest fan!!!
          thanks a lot!
            monkeybss
            I seem to have a problem too. I can see the toolbar but the offset doesn't work (Su7,7.0.102470), the line-on surface does, but nothing else seems to work.
            I'm not familiar with ruby, but it feels like some setting might be wrong (like a variable in Autocad).
            Later..
            Just being stupid, I forgot to load in "preferences". Works like a charm!
              Arthaxx
              • H Offline
                hitman47127
                thanksssssssssss a lot, 😍 😍 😍
                • E Offline
                  Efrado
                  Hi FREDO ,Thanks a lot for this Magnificent gift. Following the PDF I was traying to reproduce the "section pie" but I could not .How did you do? Thanks "
                  • fredo6F Offline
                    Use the 'Ring' capability of the TOS shapes. In the VCB, you type an length, posititive or negative' followed by 'x', and you get the shape contour with the specificed offset. This is explained in the doc, in the Shapes section (page 9).
                    Hope this answers your question.
                    • E Offline
                      Efrado
                      As always your Kindness is OUT OF DOUBT ----PRICELESS-----Thank You
                        mrljfr1
                        Thanks,what a great work!
                          lorca
                          Am I doing something wrong? I place CadFather icons in the TOS v13 folder but I still get Fredo icons. I don't mind really but I wonder what is happening.
                          • fredo6F Offline
                            The folder is named TOS_Dir_13. I guess this is what you mean.
                            I also assume that:
                            • you unzipped correctly the CadFather icons into the folder (can you check the right files are there)
                            • you restarted Sketchup
                            • if you use both SU6 and SU7, you did not mix up the file copy.
                            Otherwise, this looks strange. You can always delete all the png files in the folder and replace them by CadFather's files.
                              lorca
                              I also assume that:
                              I extracted the Cadfather icons into the TOS_Dir_13. I deleted your icons to be sure I restarted sketchup but I still get your icons.
                              • fredo6F Offline
                                Maybe you still run TOS 1.2.
                                Can you check the file ZLoader__onSurface.rbto verify that it contains the correct reference to TOS_Dir_13 (alternately, reinstall the plugin, making sure you overwrite all files, including ZLoader__onSurface.rb).
                                  lorca
                                  I remember that a week ago I installed Offset On Surface version 1.0. Then I installed TOS version 1.1(That one has the toolbar that I want to get rid of) I eliminated both plugins before installing v1.3 except for LibTraductor.rb. Btw, the new icons overwrote yours but there was still some old icons of yours leftover.
                                    lorca
                                    Fredo, I noticed something else. I have SU v7 and I have this other plugin with a SU example. This example file is of SU v6.4 and to my surprise I can see CadFather icons there! But not in my SU v7.
                                    UPDATE
                                    Fredo, I uninstalled all the plugins that I downloaded to see if there was a conflict. I reinstalled your plugin first with CadFather icons and voila it worked!! So, it seems that there was a conflict with another plugin. I will go ahead and reinstall one by one the rest of the plugins too see which one is the culprit. I'll let you know.
                                    UPDATE #2
                                    Fredo, the second plugin I reinstalled was your FredoScale 2.0g and now I get a warning message in SU:
                                    undefined method []' for nil:NilClassError Loading File ZLoader__OnSurface.rb undefined method []' for nil:NilClass
                                    • fredo6F Offline
                                      NEW VERSION 1.5a - 17 Sep 09
                                      The main evolution is the addition of a Button palettefor better visualizing and modifying the various options of each tool. Freehandalso gets a Point & Click mode, which makes it equivalent to a Polyline On Surface, With and Without inferences (easier to draw over images).
                                      See attachment and documentation in main post of this thread at http://forums.sketchucation.com/viewtopic.php?f=180&t=11212#p76625
                                      ToolsOnSurface 1.5 requires to install LibFredo6 3.4 or higher.
                                      See post at http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17947&p=144178#p144178 for download and installation.
                                      PS: Many thanks to Takeshi who helped to troubleshoot some issues on Mac.
                                        Ben Ritter
                                        Fredo6,
                                        I can't find the attachment.
                                        • fredo6F Offline
                                          It is at the end of the first post of this thread.
                                            Ben Ritter
                                            Never mind, I found it. My settings were preventing me from going back to the first page.
                                            By the way, thank you very much.
                                            • 11
                                            • 31
                                            • 32
                                            • 9 / 32
