    What is this and how do i remove it?
    4 Posts 3 Posters 458 Views 3 Watching
      joakimzickert
      http://img6.imageshack.us/img6/2350/skinkpinne.png
      What is this?(marked with red) Why does it appear and HOW DO I REMOVE IT? I've allready updated my videodrivers and i even tried with another computer.
      As you might see i am planning a kitchen and what disturbs me is that i cant colour those "color-shifting" areas
      Thanks for your help!
        johnsenior1973
        You've got clashing faces in your model. That means you have two faces occupying the same space.
        I'm assuming that the cabinets in your model are components. Select all the cabinets, copy them, delete them, then there should be the other faces where the components were, delete them, then go to Edit>Paste In Place and the components will be pasted in their original place.
          joakimzickert
          Thanks a lot, problem solved!
          Is it impossible to draw to flat faces onto each other without clashing them?
            Rather consider these faces as they are trying to "fight" for visibility. In fact, in real world (as everything has some thickness) they don't appear so you should also try to avoind this scenario.
