    Unexpected lines
    3 Posts 2 Posters 482 Views 2 Watching
    • arail1A
      arail1
      I have purged everything in the file, checked Hidden Geometry, set the file to Wireframe, but nothing I do can seem to get rid of the two thin lines that you see emanating from the center at about 7 o'clock.
      I'm not sure if this is a problem in V-Ray or in SketchUp.
      Any thoughts on where else I might look to track them down will be very appreciated.SpiralSlatsVRayJune23Top640x640.jpg
      • bazB
        baz
        Seeing as nobody else has jumped in, check out this post:
        http://forums.sketchucation.com/viewtopic.php?f=180&t=13711&start=0
        Im not sure if this is the right way to put a link, if it doesnt work, search for a recent post by Jackson called
        [PLUGIN] Remove group materials, leave geometry materials?
        It seems there is an issue with su materials annd Vray.
        baz
        • arail1A
          arail1
          Thanks baz -
          I think somewhere in that long thread is the answer I'm looking for, and this is my starting point (I'm quoting from the thread) -
          "while on the subject of helping out vray, vray SR1 creates vray materials of all materials in the scene even the materials on lines (multi-coloured from CAD imports) could there also be a script to remove all materials from lines? that way vray wouldnt create any unnecessary materials"
          Only after reading that comment did I realize that the two offending lines only exist in the original CAD file.
