    [Req] Export g-code for 5 axis cnc router
    14 Posts 5 Posters 5.0k Views 5 Watching
    • ely862meE Offline
      ely862me
      Recently i find out about this http://forums.sketchucation.com/viewtopic.php?f=72&t=20436
      And i was wondering if someone can do a script that write g-code for 5 axis not just for 3.
      Is this possible in Sketchup?
      I don t know exactly the process of exporting this g-code...maybe for 5 axis router will have to be other software different for that Mach 3 which is used for 3 axis.
      Please if u know much more about this let me/us know how these things works.
      Thanks a lot!
      Attached is the plugin for 3 axis.
      Phlatboyz_v0.918.zip
      Hope to hear soon ur opinion !
      Elisei
      Elisei (sketchupper)
      Come and See EliseiDesign
      • Chris FullmerC Offline
        I don't understand what 5 axis means. And what do you need it for? Do you own a machine that work in 5 axes?
        • ely862meE Offline
          ely862me
          i don t own one yet but i want to make one(if i can )..
          i want to be able to cut my cars in foam with a 5 axis cnc router πŸ˜„
          anyway soon a friend of mine will buy a 5 axis cnc router ..the point is that these machines accept data only from solidworks, catia and so on, especially cad-cam programs 😐
          Would be awesome if somebody can make a script to write such a code for these machines directly from sketchup as phlatboyz script ...
          I m not sure exactly if g-code is used for 5-axis machines... maybe i ll ask this on phlatprinter site..
          Anyway ,again, if somebody knows how these things works please let us know!
          Thanks,Elisei!
          Attached is a 5 axis milling machine cutting a jet ski(anyway,this is not the important part,the important part is to write that code which drive the machine)
          [flash=425,344:oa6ppzqe]http://www.youtube.com/v/Zsdo92HpnKg&hl=en&fs=1&[/flash:oa6ppzqe]
            Any reason you want it directly from SU?
            Is there flaws with the options that exist now that involves exporting?
              I think if you buy one, it comes with its own software to convert different filetypes. .skp probably is not one of them, but if you take the time to make a watertight model, you should be able to convert it to .dwg or .3ds or whatever type it does support, then it can convert to whatever it needs.
              That was my experience using one to help with a landscape model.
              • ely862meE Offline
                ely862me
                OK..what means to make a car watertight? 😳 πŸ˜†
                  I wrote a little plugin to help with making models watertight. It goes through the model and adds a text label to each face that is not watertight. Check it out here:
                  http://forums.sketchucation.com/viewtopic.php?f=180&t=17876
                  TIG also has a script that goes through a model and tries to find all non-watertight faces and fix them autoamtically. Its referenced in the thread I linked to above, or the direct link to it is here:
                  http://forums.sketchucation.com/viewtopic.php?p=143720]
                  Hope those help,
                  • daikuD Offline
                    daiku
                    As far as I know, the CNC machines need output from a solid modeler, and Sketchup is a surface modeler.
                    http://en.wikipedia.org/wiki/Solid_modeling
                    Clark Bremer
                    http://www.northernlightstimberframing.com
                      Most CNC machines can work with a various file types. You just have to find one that SketchUp can get to somehow. So if they take .3ds or .dwg. The machine normally should be able to convert to a useable file type. So it can still work from surface model files. They just HAVE to be watertight so they can be converted into solid model files.
                      • ely862meE Offline
                        ely862me
                        Yes,i ve seen myself that the smooth is lost when exporting stl..i ve downloaded the plugin for exporting stl ..
                        I think smoothing will be the problem.
                        Can t wait to see what they think!
                        Thanks a lot!
                        Elisei
                        • ely862meE Offline
                          ely862me
                          Nice...i bet if they make a 1:10 scale will take about 1000 $, which is too much for a scale model, which i, probably,can make with less than 100 $ manually(but not so perfect).
                          Anyway what i wanted is to be sure if the exported stl file is still smooth when running it on a cnc 5 axis machine..
                          Thanks for updates!
                          Elisei
                          • ely862meE Offline
                            ely862me
                            Very interesting..it looks that this 3d printing is good for buildings,especially models with flat areas... i bet that the printer can t make the surface smooth,because now(in the stl file) the triangles are separated,they represent an individual face for the printer; the printer will cut every face in the manner it is(so,good bye smooth surface).
                            This is the main reason i asked for a direct exporter of any code that it s accepted by a cnc 5 axis,because when exporting to other formats the properties of the skp files are lost(especially on organic surface).
                            Solidworks,catia,alias works with metal sheets,u make the main splines then u loft them and they become clean surfaces ready to be milled as they are...that s why the professionals works with them..
                            Anyway until a better solution i think the best way is to cut sections and make the surface manually .
                            Elisei
                            • ely862meE Offline
                              ely862me
                              No problem, i wouldn*t pay that much money for it being given the size.
                              Thank you very much for the information u provided,it*s good to know!
                              Elisei
                              • ely862meE Offline
                                ely862me
                                I understand that is easier to convert a skp file into a file format supported by the cnc software than writing that code in sketchup ..
                                The point is that when exporting from sketchup to other formats u don t know exactly what sketchup export,and usually u get lot of problems because the formats are not 100% compatible. U,probably, need to check them there as well ..
                                So far i intent to use the sections i cut from my car to achieve the car shape manually in foam.
                                It would probably be much better to start learning some cad-cam programs but they are too hard for me..and in sketchup i really feel inspired(that s why i still stay on it).
                                Elisei
