    [Plugin] ExtendTool v0.2 (update 20090708)
    31 Posts 15 Posters 41.0k Views 15 Watching
    • majidM Offline
      majid
      yes I see 🤣 , when it didn't worked for me , I deleted it ... šŸ˜„, then I thought that maybe other plugins interfer it , so i shared the plugins folder picture..
      also all lines are coplanar , and i repaired the inserted cad file by hand (149 trim extend needed ... šŸ˜„ as the autocad is going to be more fuzzy!!!!)
      ok ... I am thinking that if we could have a better (smarter) cad import plugin? bkz when we import cad files , then su convertes circle to 24 sided su native cirles , and then there would be a gap between the circle and rest of the model... so maybe we could resolve this with a ruby cad importer!!! ā“ šŸ’­
        Matt666
        majid,
        this plugin cannot do what you describe... Perhaps try ExtendCloseLines?
        Frenglish at its best !
        My scripts
          Tig has made something for that!
          I must refind that šŸ˜‰
          Found! changearcsegments šŸ˜‰
          • EarthMoverE Offline
            EarthMover
            Matt,
            It works well when I have a face selected, however when I select a coplanar edge to extend to, I get a "no limit found" error in the ruby console. Any ideas?
            Content Creator at Skapeup
            • JClementsJ Offline
              JClements
              Hi Matt:
              Works well for me. I like the simple UI.
              Could a similar script be developed to extend (move) a vertex (which may or may not be part of a face)?
              How it might work: initiate script, pick (click) on the anchoring endpoint or guidepoint, then click on the vertex you want to move. It would basically be the same as manually doing a move-and-drag or alt-move-and-drag function, but inferencing to anything other than end-point or guide-points would be blocked.
              This would be helpful when trying to move a vertex a very small distance in an area with lots of geometry.
                Matt666
                EarthMover,
                Thank you for testing it!
                Can you post tested file, please? Can you show me "limit" lines or faces, and desired edges to extend?
                I have no problem here. Oh yes I had a problem, but I corrected the plugin. Update will come soon.
                JClements,
                Thank you for the comment!
                I will "investigate" to find if I can do this plugin... For the moment I think it's out of my ruby level! šŸ˜†
                My scripts
                • Chris FullmerC Offline
                  Hey Matt, great plugin, thanks! I've just started a new project and I am putting this to good use. Thanks! Also, I edited my copy to make it so that holding shift will delete the geometry instead of extending it. I have lots of lines that are just a little too long. So instead of extending them, I want to "trim" them, like in autocad. So that little tiny bit of functionality is very helpful.
                  So a HUGE thanks, this is quite useful,
                  • utilerU Offline
                    utiler
                    Hey Chris, thats a great idea!!! wouldn't mind seeing that incorporated into matt's plugin.... šŸ‘
                    Just Curious...
                      Matt666
                      Glad to help you, Chris! šŸ˜„
                      I updated code today. If you want I can update the code again with your improvment? Do you agree? Can you show us your bit of code?
                      šŸ˜‰
                      My scripts
                      • mitcorbM Offline
                        mitcorb
                        I had difficulty with the plugin.
                        In the drop down menu I see Selection with a fly out trigger that doesn't fly out to show Extend Edges. I posted in Thomthom's thread on Selection Toys, thinking that Selection was part of his suite. I will try to unload and reload to see if it works better.
                        I have a mild concern that other recently downloaded tools may be interfering--not sure.
                        Best Regards,
                        mitcorb
                          stefx
                          Ehi,
                          I am using Mac and it sounds that it doesn't work...
                          šŸ˜ž
                          Any another feedback?
                          Stef.
                            Try my 2D Tools Fillet or Adjust tools..........
                              mirale999
                              mitcorb say:"In the drop down menu I see Selection with a fly out trigger that doesn't fly out to show Extend Edges."
                              I have the some problem but I can use the tool, the submenu is like this picture:2011-09-12_130303.png
                              paranoia is a higher form of awareness...
                                Matt666
                                Ah sorry, try to delete this block at the beginning of the code:
                                <span class="syntaxdefault">ifĀ </span><span class="syntaxkeyword">!</span><span class="syntaxdefault">file_loaded</span><span class="syntaxkeyword">?(</span><span class="syntaxstring">'TtMn_selection'</span><span class="syntaxkeyword">)</span><span class="syntaxdefault">Ā then<br />Ā Ā Ā Ā ifĀ $submenu<br />Ā Ā Ā Ā Ā Ā Ā Ā organizerĀ </span><span class="syntaxkeyword">=</span><span class="syntaxdefault">Ā $submenu<br />Ā Ā Ā Ā else<br />Ā Ā Ā Ā Ā Ā Ā Ā organizerĀ </span><span class="syntaxkeyword">=</span><span class="syntaxdefault">Ā UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">menu</span><span class="syntaxkeyword">(</span><span class="syntaxstring">'Plugins'</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">Ā Ā Ā Ā end<br />Ā Ā Ā Ā $TtMn_selection_plugins_submenuĀ </span><span class="syntaxkeyword">=</span><span class="syntaxdefault">Ā organizer</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_submenu</span><span class="syntaxkeyword">(</span><span class="syntaxstring">'Selection'</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">Ā Ā Ā Ā UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_context_menu_handlerĀ doĀ </span><span class="syntaxkeyword">|</span><span class="syntaxdefault">menu</span><span class="syntaxkeyword">|<br /></span><span class="syntaxdefault">Ā Ā Ā Ā Ā Ā Ā Ā $TtMn_selection_contextual_submenu</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">menu</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_submenu</span><span class="syntaxkeyword">(</span><span class="syntaxstring">'Selection'</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">Ā Ā Ā Ā end<br />Ā Ā Ā Ā file_loaded</span><span class="syntaxkeyword">(</span><span class="syntaxstring">'TtMn_selection'</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">end</span>
                                šŸ˜•
                                My scripts
                                • mitcorbM Offline
                                  mitcorb
                                  Hi, Matt:
                                  Is this block of code intended as a disambiguation, or differentiation of the two Selection tools? Or was it intended as way to allow coexistence?
                                    poru
                                    The plugin doesn't work when edit a group, you need to explode the group extend and regroup...
                                      Yes, it does work when editing a group. There is no need to explode the group first.
                                        It works on a selection.
                                        So therefore it only works on lines that are all in the same 'context'.
                                        Editing a group allows you to select lines within the group.
                                        BUT if you want to process lines that are in the group AND lines outside it then you cannot, because you can't select lines with both contexts at once.
                                        Then you need to explode the group so all lines are selectable in the common context.
                                        Alternatively, select the lines you want to use outside of the group, Edit+Copy, edit the group and Edit>Paste_In_Place.
                                        Then those lines are duplicated inside the group; select them and other lines and do the processing.
                                        If necessary delete the unwanted duplicated lines.
                                        Alertnatively-ly, Edit>Cut the lines and Edit>Paste_In_Place into the group's context etc...
                                        It depends what final outcome you want...
                                          lothian
                                          m'eh...
                                          the tool needs work... its interface, capability, and intuitive-use are lacking (expected for a "zero-dot" rev).
                                          add the ability to extend arcs as well.
                                            Why don't you write a better version, then?
                                            With your input, this post could be even better šŸ’—
