    ⚠️ Attention | Having issues with Sketchucation Tools 5? Report Here
    [Plugin] ExtendTool v0.2 (update 20090708)
    31 Posts 15 Posters 37.4k Views 15 Watching
      Matt666
      Hi all!
      Here is a plugin that extend edge you pointed on. It tries to work like acad Extend tool...
      Usage:
      • First select edges or faces that will be limits of the extended edges. If you don't select anything, script will select all the model as the limit.
      • Point on each edge you want to extend. Be careful of side of the edge pointed. It determinates sense of the extension.
        I hope it works with Win and Mac version. A cursor replaces standard SU cursor.
      This script may contain bugs... No. IT contains bugs! Please be patient if you find a bug, I will do my best to update the script.
      All suggestions/improvments are welcome!
      πŸ˜‰
      [EDIT] 20090708 - V0.2
      New extended edges broke edges of the limits. So limits changed while script worked.
      Menu plugins/Extend edges
      Context menu/Selection/Extend edges
      In the ruby console: "Matt_Edges.extend"
      Frenglish at its best !
      My scripts
        rv1974
        A very good intention Matt!
        Make it a perfect example of the reverse engenering πŸ˜› :
        To select boundary at the beginning and then with window select a bunch of lines to be extended.
        Maybe trim with shift could be added?
        P.S. And what about extend faces?
          Matt666
          Hi rv1974!
          With this method you can't select side of edge you want to extend... That's why I copied Autocad method. A possible improvment would be to select side of multiple edges by a path, like acad tool...
          My scripts
            rv1974
            2009-06-17_0937.swf
            I mean something like this.
            P.S. BTW how to embed video in the post?
            • majidM Offline
              majid
              it doesn't work for me 😞
                I must try it πŸ˜‰
                Edit: works fine for me! 😎 (PC)
                  Matt666
                  Of course lines must coplanar. That's strange it doesn't work for you...
                  Can you show me errors in the ruby console please?
                  Thank you!
                  Nice to read that Pilou! πŸ˜„
                  My scripts
                  • majidM Offline
                    majid
                    I imported a cad file , and as usuall it had lots of stray lines...so I desided to use the plugin, but nothing happend 😞...
                    here is my plugin folder view :
                      Matt666
                      Thank you for your answer.
                      Sorry, but... I don't see any ExtendTool folder and ExtendTool.rb in your plugin folder...
                      Can you try to download it again and to unzip it directly into plugins folder, please?
                      My scripts
                      • Chris FullmerC Offline
                        Majid, the plugin isn't in there. Where did you put it?
                        Try downloading and installing again.
                        • majidM Offline
                          majid
                          yes I see 🀣 , when it didn't worked for me , I deleted it ... πŸ˜„, then I thought that maybe other plugins interfer it , so i shared the plugins folder picture..
                          also all lines are coplanar , and i repaired the inserted cad file by hand (149 trim extend needed ... πŸ˜„ as the autocad is going to be more fuzzy!!!!)
                          ok ... I am thinking that if we could have a better (smarter) cad import plugin? bkz when we import cad files , then su convertes circle to 24 sided su native cirles , and then there would be a gap between the circle and rest of the model... so maybe we could resolve this with a ruby cad importer!!! ❓ πŸ’­
                            Matt666
                            majid,
                            this plugin cannot do what you describe... Perhaps try ExtendCloseLines?
                            My scripts
                              Tig has made something for that!
                              I must refind that πŸ˜‰
                              Found! changearcsegments πŸ˜‰
                              • EarthMoverE Offline
                                EarthMover
                                Matt,
                                It works well when I have a face selected, however when I select a coplanar edge to extend to, I get a "no limit found" error in the ruby console. Any ideas?
                                Content Creator at Skapeup
                                • JClementsJ Offline
                                  JClements
                                  Hi Matt:
                                  Works well for me. I like the simple UI.
                                  Could a similar script be developed to extend (move) a vertex (which may or may not be part of a face)?
                                  How it might work: initiate script, pick (click) on the anchoring endpoint or guidepoint, then click on the vertex you want to move. It would basically be the same as manually doing a move-and-drag or alt-move-and-drag function, but inferencing to anything other than end-point or guide-points would be blocked.
                                  This would be helpful when trying to move a vertex a very small distance in an area with lots of geometry.
                                    Matt666
                                    EarthMover,
                                    Thank you for testing it!
                                    Can you post tested file, please? Can you show me "limit" lines or faces, and desired edges to extend?
                                    I have no problem here. Oh yes I had a problem, but I corrected the plugin. Update will come soon.
                                    JClements,
                                    Thank you for the comment!
                                    I will "investigate" to find if I can do this plugin... For the moment I think it's out of my ruby level! πŸ˜†
                                    My scripts
                                      Hey Matt, great plugin, thanks! I've just started a new project and I am putting this to good use. Thanks! Also, I edited my copy to make it so that holding shift will delete the geometry instead of extending it. I have lots of lines that are just a little too long. So instead of extending them, I want to "trim" them, like in autocad. So that little tiny bit of functionality is very helpful.
                                      So a HUGE thanks, this is quite useful,
                                      • utilerU Offline
                                        utiler
                                        Hey Chris, thats a great idea!!! wouldn't mind seeing that incorporated into matt's plugin.... πŸ‘
                                        purpose/expression/purpose/....
                                          Matt666
                                          Glad to help you, Chris! πŸ˜„
                                          I updated code today. If you want I can update the code again with your improvment? Do you agree? Can you show us your bit of code?
                                          πŸ˜‰
                                          My scripts
                                          • mitcorbM Offline
                                            mitcorb
                                            I had difficulty with the plugin.
                                            In the drop down menu I see Selection with a fly out trigger that doesn't fly out to show Extend Edges. I posted in Thomthom's thread on Selection Toys, thinking that Selection was part of his suite. I will try to unload and reload to see if it works better.
                                            I have a mild concern that other recently downloaded tools may be interfering--not sure.
                                            Best Regards,
                                            mitcorb
