    โ„น๏ธ Licensed Extensions | FredoBatch, ElevationProfile, FredoSketch, LayOps, MatSim and Pic2Shape will require license from Sept 1st More Info
    Rogue's W.I.P's!
    922 Posts 55 Posters 142.5k Views 55 Watching
      BLANK
      I just seem to get very rough metal and body paints...
      Ooooh. I actually change the metal coverage. Usually it's 0.2, I go for 0.05 or 0.01; keepin' it minimum. I don't really like the flakes - it makes it look like a tacky paintjob. Plus, the "metal" and "base" is the same (you probably did that, just mentioning it).
      You should send me your procedures so I can see what you've done.
      @wacov said:
      1hr 30min.
      Holy s**t! I feel your pain. I thought 8 mins. was far too much...
      If only the Yakuza had heard of Australia... [url=http://sketchup.google.com/3dwarehouse/details?mid=cd46471677a3e490b8f4e95477ed5df:21uuz2ul]Ford Falcon sedan conversion[/url:21uuz2ul] [img:21uuz2ul]http://lh5.ggpht.com/_DXlDhsgmn6Q/S2Qi2PU4IJI/AAAAAAAAAuE/AqSICmCNiS4/s800/Untitled-1.jpg[/img:21uuz2ul]
        remus
        If you think 1 hour 30 is bad i recommend you stay away from sss and cauchy b for the moment ๐Ÿ˜„
          MrPlanet
          You should try 45 hours straight with a failed render ๐Ÿ’š
          I reject your reality and substitute my own.
          • W Offline
            Wacov
            Lol, I probably shoulda stopped at 1 hour. But it was still a little grainy ๐Ÿ˜„
            I could've done it in under 20 mins at a lower res, but it's just not the same... the time doesn't really bother me anyway, there are other things I can be getting on with. And Indigo's images are so perfect O_O
              BLANK
              Eeek, keep your horror stories to yourselves... ๐Ÿ˜ž
              • Roguer1R Offline
                Roguer1
                Lol. ๐Ÿ˜„
                Good render btw, very nice!
                Very similar to my very old renders of my Maverick. I think I used Indigo too.
                Find all my models on the [3D Warehouse](https://3dwarehouse.sketchup.com/user/d8bb4d13-3b01-44a0-a007-4a77a32b6433/Ben-B?tab)
                • Roguer1R Offline
                  Roguer1
                  Thanks for the render advice Shams.
                    MrPlanet
                    Holy **** That looks AWESOME! How much render time was there? If it was under 15min, i will be amazed ๐Ÿ˜„
                    • Roguer1R Offline
                      Roguer1
                      Here is another
                        BLANK
                        Nice! I'm still trying to work out how to make the lights "work", as if they're switched on; no success...
                        It must be. A similar render (background off; ground reflections on; 1600x1200 res.) took me 7-8 mins.
                          JaViXP
                          Those renders are awesome Ben!
                          "Giving up is way harder than trying"
                          JaViXP's Rendering
                          • Roguer1R Offline
                            Roguer1
                            Well Shams, your computer was most likely just doing the render. I had quite a lot else going on at the same time as the renders so they took about 50 minutes each. I only have a single core processor so nothing super fast.
                            Here are more renders
                            http://picasaweb.google.com/RogueAutomotiveDesign/Other3D
                            I'm so happy with the results
                              BLANK
                              Sweet renders!
                              Oh, I see my problem. My pc is actually dual-core. It's just the RAM is below the minumum requirement. Looks like I bought the word "Vista" rather than the computer...
                              Anyway, the Dorifto Cobra is done. Here's a screenshot of the awesomeness:
                              Me pulling a Vaughn Gittin Jr. impression. Yes, those captions and smoke DO show up.
                              The controls are a bit tricky. The controls on the left are inverse (S is forward; W is backward) - it's the only way I guess. I could've removed the controls on the left, but that would leave the car one-speed, thus making it harder to drift. Oh well, have fun.
                              2009 Trojan Cobra (Dorifto Edition).skp
                              • Roguer1R Offline
                                Roguer1
                                Fun game Shams. Although its a little odd without markers.
                                Here is a little something people might be interested in:
                                http://www.youtube.com/watch?v=sKQs9OU-Rig
                                • Roguer1R Offline
                                  Roguer1
                                  BLAH, I'm soo board!
                                  More renders
                                  http://picasaweb.google.com/RogueAutomotiveDesign/Other3D#
                                  • alexandre skA Offline
                                    alexandre sk
                                    nice models ๐Ÿ˜ฎ
                                      JaViXP
                                      Cool thanks for the video Ben! I finally learnt how to do a good render
                                      JaViXP's Rendering
                                      • Roguer1R Offline
                                        Roguer1
                                        ๐Ÿ‘
                                        I just noticed what Crystal does; it projects whatโ€™s on the other side. I have started using Glass, as I should have XP. I noticed after looking at the render of my Falcon
                                        • Roguer1R Offline
                                          Roguer1
                                          I have redone my Falcon Renders and have done some GT S renders too.
                                          I might actually start some modeling today
                                          http://picasaweb.google.com/RogueAutomotiveDesign/Trojan3D
                                          • Roguer1R Offline
                                            Roguer1
                                            This is sooo boring!
                                            Here is a little more work (1 or so hours) on my Mach II:
                                            ford mach II.zip
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 46
                                            • 47
                                            • 21 / 47
