    Scaling textures
    4 Posts 3 Posters 510 Views 3 Watching
    • Z Offline
      ziegulpu
      Hello,
      I have scaled textures before in SketchUp using the color pallette. Next to where you can adjust the color on the color wheel there was a slider to scale the texture and set opacity. This is no longer there in edit on the color tool pallette. Can you turn this option on/off? How can I get it back?
      Thank you,
      Z
      • Alan FraserA Offline
        Alan Fraser
        The opacity slider and the text boxes where you can type in a new dimension for the image scale should still be there on the Edit tab. They will be greyed-out unless you have selected the In Model palette.
        3D Figures
          @alan fraser said:
          They will be greyed-out unless you have selected the In Model palette...
          ...AND a texture (colour is enough for transparency) to edit.
          • Z Offline
            ziegulpu
            Thank you, I found them. I did take the steps to select the texture in the tool pallette then try to edit it. They still weren't there. I then, uh um, extended the top half of the palette and found them there. Sometimes it so simple, yet so far away. I figured all options in that section would have been displayed. They have been before. They just, just disappeared.
            Thank you for your advice.
            Z
