    SketchyPhysics 3x June 27 version.
    95 Posts 12 Posters 28.4k Views 12 Watching
      Physicsguy1
      Since this version is unstable, it would be best if you created a method that stops the simulation, after an amount of time, if something strange happens, or the ismulation gets laggy(breaking feature).
        CPhillips
        @wacov said:
        In the ontouch event, is the speed the speed of the collider at impact... and pos the point of impact?
        Yes.
          CPhillips
          @wacov said:
          Chris, how DO you freeze objects in script? Has that been added yet? I've tried frozen=true and frozen(1), but no luck.
          Doesn't look like I have hooked that up yet.
            CPhillips
            There isn't a "magic bullet" for that. I need to find all the different ways it can break and then tackle them one at a time.
            Post any code you find that breaks the sim and I'll put the right error checking in.
            • W Offline
              Wacov
              Pretty nice cloth demo. Once again, totally copyable! I love the scripted joints
              Copyable cloth.skp
                CPhillips
                Nice! 😄
                  Physicsguy1
                  That's a nice representation of cloth, Wacov!
                  • W Offline
                    Wacov
                    Thanks guys! One thing I'm finding with the cloth is it tends to collide with itself. That seriously slows stuff down, and it's not really neccessary for a semi-realistic simulation. Can we have object-specific collision detection? So, give the choice to either collide with everything, collide with everything except '...', or collide with nothing but '...'. Keep it pretty intuitive, so using a string finds objects of that name, a var for specific objects, and let us put them into an array if needed.
                    So, on the cloth, I'd name all the bars the same, and tell them to collide with everything except each other. You might also be able to make a crude fluid flow effect by creating spheres that only collide with the static mesh.
                      phy
                      I love the new Script field and script but I was wondering is there any way you can control a scripted joint with a slider or key.
                      Tableau de comparaison de Staxyn s'agit d'un mГ©dicament uniquement sur ordonnance.
                        JaViXP
                        Just a little test. Hit Play and see what happens 😉
                        Download this file
                        "Giving up is way harder than trying"
                        JaViXP's Rendering
                          Physicsguy1
                          YES!! The simulation finally registers in-simulation created objects!
                            CPhillips
                            In the physics engine you would need materials to do that. So don't expect it until SPIV.
                            One thing you could do that might speed things up is to change the connect script to something like this.
                            ontouch{|t,s,p|
                               connect(t,"ball") if frame==1
                                #empty the ontouch event after the first frame.
                                #this will ensure that ontouch isnt called again.
                               ontouch{} if frame>1
                              CPhillips
                              Not yet. 😞 But I will do that next.
                                CPhillips
                                JaViXP it will work better if you change the onend to this:
                                onend{
                                   group.erase!
                                  Physicsguy1
                                  Will we be able to embed sound files anytime soon?
                                    Physicsguy1
                                    I tried something similar to javixp's line generator, but the groups I generated are not registered.
                                    scriptedrandomcube.skp
                                      CPhillips
                                      I dont know about the sound. I havent touched that code in a while, but I will see if it still works and let you know.
                                        Physicsguy1
                                        Tracks'n'Treads are much easier. I realy like the new version!
                                        tank.skp
                                          CPhillips
                                          Me too! Self connecting joints are a feature I have been trying to achieve since version 1. I HATE the JCT. Its hard to explain, tedious to use and is the reason you cant copy jointed objects. Its THE major reason I started SPIV. So, I am really glad it turns out to be possible in SP3.
                                            CPhillips
                                            Here is an example of a very simple camera system.
                                            The first example puts the camera eye at the position of the sphere and looking at [0,0,0].
                                            The second example finds the cone in the scene and looks at that. Note you can drag the cone and the camera will follow.
                                            The @simulation.camera.set commands parameters are location of the eye, the target and the "up" direction.
                                            The camera is the same as the camera in the Sketchup API:
                                            http://code.google.com/apis/sketchup/docs/ourdoc/camera.html
                                            camerasimple.skp
                                            cameraFollow.skp
                                            • 1 / 5
