    [Plugin] MXM Reporter (Maxwell Render)
    47 Posts 8 Posters 97.8k Views 8 Watching
    • F Offline
      frv
      Hi Vodka,
      some further testing show me that sometimes the .mxm path is neccesary but sometimes not. I had for instance a material that worked both ways but other only worked when I attached .mxm to the material name in SU.
      more request, maybe impossible.
      Can you make the list in MXM reported a little more interactive. Like the option to change material names in the list or rename them and maybe even to delete a set of materials from the SU file. In SU I can not delete more than one material at once. Can you imagine deleting 20 materials by deleting them one by one.....
      Ok, thanks again a lot,
      Francois
      • V Offline
        vodkamartini
        Ok, I'm now parsing the MXMPath line in the MaxwellRender.ini config to accommodate any spaces before the equals sign. That was just another case of a formatting difference between windows and osx.
        I hardcoded in the "/Applications/Maxwell 1.7" path for mxed. It should work for you now but I'd like to find a more generalized solution in case someone changes their installation directory or upgrades to a new version of maxwell. On windows there is an environment variable (MAXWELL_ROOT) that will always point to the correct folder. Would it be possible for you to send me the MaxwellExport.rb from your plugins folder so I can look and see if NextLimit is just hardcoding their path as well?
        I changed the display of assigned auto mxm files (the purple entries) to not include the auto mxm path, like you had asked.
        I'm not sure about moving the continue button on the scan list though. I kind of did it that way so that people would see any highlighted "ambiguous" mxm files. Right now you can hit the "end" button on your keyboard to jump to the bottom of the list. I guess I can add a "jump to bottom" link or something.
        Also, that "ambiguous material names" list is just showing you that there are mxm files with the same name in different subfolders within your auto mxm path. So you might have a file named concrete.mxm in an "outdoors" folder, and another file named concrete.mxm in a "construction" folder. I don't know what method the exporter is using to decide which file gets applied on export. My plugin will just assume the first mxm file it finds is the correct one, and will highlight any other mxm files with the same name in red to let you know that they won't be used by MXM Reporter. So it's best to use the "ambiguous material names" list to help you rename your mxm files so that they're all unique.
        The MXM Reporter dialog box should already be resizable, and it should remember its size and position when you close and reopen it. I do have it set to a minimum size of 640x480, however. Are you trying to make it smaller than that? For me things start to get pretty cramped and unreadable when you go that small. Maybe you have safari's font size set to be smaller than normal? Anyway, I just changed the minimum size to be 400x300. Hopefully that's small enough for you.
        I would definitely like to know the official policy on naming the sketchup materials. The helpfile that comes with the maxwell plugin on windows doesn't mention using .mxm extentions at all. Right now I have it set so that on OSX you can have the sketchup materials named with or without the .mxm extension and they will be matched up with the auto mxm files in MXM Reporter. If the maxwell exporter always works with the .mxm extensions then just use them exclusively. I bet there is something about the filenames that are causing some to work without the extension and others not to. If you experimented enough you could probably figure it out.
        I would rather wait and make sure all these other issues are squared away before I start adding more features. From what I've seen the sketchup api doesn't even allow you to rename materials, so I would be doing hackish workarounds like creating a new material and copying over all the attributes. Then I would have to make sure all the stuff you had painted with the old material is now referencing the new material, etc, etc, etc. As far as deleting 20 sketchup materials like in the example you gave, I would do it by using the "purge unused" command in the sketchup material panel. In the future I can probably add more options for things like that in the context menus that pop up when using the right mouse button.
        Anyway, let me know how this version works out, and remember to send the MaxwellExport.rb file if possible. It would also be nice if you could find a way to recreate that bug you mentioned seeing one time where selecting a material in MXM Reporter doesn't select it in sketchup's material panel. I know you can do it by renaming a sketchup material and not hitting "refresh" in MXM Reporter, but other than that it shouldn't happen. You can also cause problems if you keep MXM Reporter open while switching between different .skp files. In those cases you should close and reopen MXM Reporter so that it binds itself to the current model. This seems to be another case of the sketchup api missing important functionaility (sending notification when the current model changes).
        MXM Reporter 0.4d
        • V Offline
          vodkamartini
          Thanks for sending the MaxwellExport.rb file. You can remove it from your post if you'd like.
          They are simply hardcoding the "/Applications/Maxwell/mxed.app/Contents/MacOS/mxed" path that I was originally using, which begs the question... does mxed even come up when used from the maxwell material panel?!
          I can't think of a reason why selecting the materials in sketchup won't highlight them in MXM Reporter on osx. It's pretty much the exact same code path as when you select the material from directly within MXM Reporter. Very strange. There are too many little things I would have to test to figure it out, so I won't waste your time on it.
          So yeah, the MXED issue seems to be the only major incompatibility left. I would really like to get that one figured out for an official 0.5 version. I've included one last test version that will print out a few addition details in the ruby console when you click on an mxm file. I realize things are pretty much working for you now, but if you find the time to test it out I'd appreciate it.
          Thanks for all your help, Francois.
          MXM Reporter 0.4e
          • F Offline
            frv
            Hi Vodka,
            it works now. Maybe I have just overlooked the proper highlight. I can not reproduce the wrong link to the SU material panel.
            What not works, there is no mxed link when you double click materials in the MXM reporter. When you double click a material in MXM reporter the associated material highlights in the SU material panel but there is no other vise versa link.
            Still, thanks a lot. It makes life a little easier this way being able to actually see a listing and getting a visual on what to expect from auto MXM.
            The ambigious names are indeed handy, I am starting to clean up my MXM library to make sure there are no longer doublures.
            Francois
            • F Offline
              frv
              Good news, when I use the color picker in SU then the material highlights in MXM reporter. That's probably also the way it is inteneded to work 😄 Very handy, makes MXM reporter even a lot more functional.
              Here is the ruby console readout when I double click on a MXM reporter material
              COULD NOT FIND MXED: /Applications/Maxwell 1.7/mxed
              FOUND FILE: /Applications/Maxwell 1.7/materials database/MXM library/BZKII materialen (Maxwell)/glas.mxm
              Now, that's exactly where the app mxed is located.
              mxed does not come up either through the Maxwell export material panel. If someone reads this and has it working under OSX please let me know.
              Thanks again,
              Francois
              • F Offline
                frv
                It seems to me that 100% white materials get confused with the default material in the SU material panel. I noticed before that Maxwell does not understand 100 % white SU materials. I have not tested this thoroughly.
                But when I want to reproduce the bug it always shows up with 100% white materials, when clicked in MXM reporter the SU default highlights.
                Hope this helps,
                thanks Francois
                • V Offline
                  vodkamartini
                  I find it hard to believe that even the official Maxwell Plugin won't let you use mxed. You ARE using the latest version of the maxwell plugin, right?. And I assume you can start mxed manually? Is that how you've been editing your mxm files, or have you always been using mxs studio? If you can start mxed from the osx finder, you should be able to do it from a terminal (by just typing in that "/Applications/Maxwell 1.7/mxed" path.)
                  Can any other osx maxwell users chime in on this one?
                  Anyway, If choosing a color in the sketchup material panel causes the material to highlight in MXM Reporter, then that may be a possible bug in the sketchup api on osx. It sounds like it's not firing the "set current material" event when you click on materials, but rather when you edit them.
                  As far as maxwell having problems with white materials in sketchup... that one is beyond me. I haven't seen anything like that over here. MXM Reporter only uses material names to distinguish between the sketchup materials, it doesn't care about colors or any other attributes. So, yeah I don't know.. if you can't find a method to recreate this bug it may have to wait until I can play on an osx machine.
                  • F Offline
                    frv
                    yep latest version.
                    And yes, the bug I can reproduce with white materials. They get confused with the default material. No idea why, mabe its just my machine or even me.
                    I will test on other OSX systems here at my office.
                    Since I am close to a deadline I will have to postpone further testing till later next week.
                    I wonder if there are any other OSX Maxwell users here, seems I am the one and only OSX guy here. Hope not....
                    Francois
                    • F Offline
                      frv
                      just found out its actually rather often that MXM reporter does not highlight the proper material in the SU material panel (OSX).
                      Its also normal that with the entity info palette the wrong materials are highlighted in the SU material panel . I see his happen with slightly larger files.
                      Francois
                      • F Offline
                        frv
                        When I click on a material in MXM reporter I see in the SU material panel the right color or texture highlighted but in the color grid in the same panel often the wrong or previous material remains highlighted. I think this is really a SU bug under OSX. Has little to do with the color white as I previously thought.
                        Francois
                        • V Offline
                          vodkamartini
                          I have to admit you've lost me, Francois. Are you saying that selecting sketchup materials in MXM Reporter DOES highlight the proper material in sketchup's material panel, but the color picker doesn't update to reflect that material? And if you simply click on the currently selected material in sketchup's material panel (the one that was just set via MXM Reporter) the color picker will update? If that's all that is happening then it's just an osx sketchup bug.
                          So just to be clear... as long as clicking on a sketchup material in MXM Reporter correctly sets the current material in sketchup's material panel, everything is fine with the plugin. So for instance, if you have the paint bucket tool active and click on the various sketchup material names in MXM Reporter, you will always be painting the correct colors regardless of what the color picker shows.. is that the behavior you see?
                          • F Offline
                            frv
                            well, the material panel under OSX is not very reliable. It does not always show all the materials. And it does not always highlight the material the colorpicker is picking up.
                            MXM reporter shows up only when activated so in combination with the colorpicker its not very handy. Each time you click geometry to colorpick the material MXM reporter dissapears to the back.
                            But once you click a material in MXM reporter the material is set under the colorpicker so that works...if only MXM reporter would remain visable while assigning materials..
                            I think you really need a OSX system for a day to see how things are different. And you should use a big file to see what happens with lots of materials. Just a few materials on simple geometry will usually work but when things are more complicated the typical OSX-SU bugs show up.
                            Thanks again,
                            Francois
                            • V Offline
                              vodkamartini
                              Yeah, I can understand the osx version of sketchup having problems. I was just trying to ensure it had nothing to do with my plugin. That said, I completely forgot that modal dialog windows acted differently in osx. This new version of MXM Reporter should now stay on top like you expect. I also made the "scan results" window start out at the bottom so you can quickly click on the continue button like you had asked for earlier.
                              I tried setting up an osx virtual machine last weekend, but was never able to get sketchup running inside it. I'm being honest when I say I don't think I'll be able to borrow a macbook and install sketchup & maxwell on it anytime soon. This plugin was never really meant to do anything but help me diagnose a few issues I was having when toying around with sketchup renders. I've since moved on to modo, and have been dealing with writing python scripts for it. Regardless, I'm still trying to accommodate you as best I can, and as long as you keep bringing osx issues to my attention I'll keep trying to fix them. Right now it seems like launching mxed is the only one left, and unless you experiment with some of the earlier suggestions I made or someone else chimes in it probably won't get fixed. But yeah, I wish I had a nice big mac pro to work on, I really do.. =(
                              MXM Reporter 0.4f
                              • F Offline
                                frv
                                Thanks a lot sofar, MXM reporter works well to sort out materials in SU before exporting.
                                I do not really care for MXED to start within SU anytime soon.
                                We are also into Modo these days. SU to us seems a dead end since Google took over. The newsletter from SU proves our feelings. Hardly any news on developments, just shows and tutorials.....
                                Hopefully within a few years we are as fluent in Modo as we were in SU. We feel Modo is one of the most interesting CAD applications to invest time in.
                                thanks again and if I have any further requests I let you know
                                Francois
                                • RichardR Offline
                                  Richard
                                  Vodka
                                  I wish I had the resources to give you and big fat mac for your great efforts! Wouldn't mind one myself!
                                  BUILTBRAND.COM.AU
                                    stefankaplan
                                    Great plugin, Vodkamartini!
                                    I've already saved alot of time using it.
                                    Only thing I miss is:
                                    1. The use of letters like "æ, ø, å" (I'm from Denmark)
                                    2. A toolbar-button. I've attached a rather simple png-suggestion for a button, but I don't know how to make a toolbar (I don't script).
                                    Thanks again.
                                    Stefan
                                    • V Offline
                                      vodkamartini
                                      Hey, Stefan.
                                      Sorry for the late response. I should get an email whenever someone posts in this thread, but that didn't happen for some reason. Luckily, I just saw the comment you left the other day in the Maxwell V2 thread.
                                      Call me goofy, but I didn't include a toolbar in the plugin because I liked the simplicity of having it be a single script file (e.g. all the html and javascript are embedded). I made a quick edit to the code to search for "mxmReporterLarge.png" and "mxmReporterSmall.png". If you place those image files alongside mxm_reporter.rb in the plugins folder you will have your toolbar. You'll need to enable it the first time you use it (View ->Toolbars->MXM Reporter).
                                      The localization part is a bit tricky. Does the actual plugin fail to work when you use those characters in material names / autoMXM paths? I can imagine there being some unicode issues with that.
                                      Also, I haven't pulled the trigger on Maxwell V2, so I can't make any claims as to how compatible this plugin remains with it. It doesn't sound like anything has really changed with the sketchup plugin/exporter, but some of the problems people are having with autoMXM in V2 concerns me.
                                      MXM Reporter 0.4g
                                        stefankaplan
                                        Wow, Thank you very much, Vodkamartini!
                                        It works like at charm.
                                        I understand the beauty of it being a single script, but I just wanted to avoid searching through my stuffed pulldowns when activating your great plugin...
                                        Don't worry about my stupid Danish letters - they tend to mess things up in other applications as well. I'll stick to the a-z system.
                                        Best regards.
                                        Stefan
                                        • F Offline
                                          frv
                                          I have had some more time to test and I am pleased to see MXM reporter works well even without autoMXM on at export in v2. So the export is fast and I do not have to copy paste material names in the SU material panel.
                                          I just asign materials through MXM reporter and the mxs file show up in Studio with SU names for the materials with the settings as they are in the original MXM's.
                                          Just perfect.
                                          • F Offline
                                            frv
                                            Hi Vodka,
                                            are you still with us here ? How's Modo ?
                                            Your plugin works great even with v2 and plugin 2.4 of Maxwell.
                                            Actually it works better than expected since I no longer autoMXM and export using your plugin. SU materials are imported into Studio with their original SU names but with the MXM settings as assigned. Even the default material is not exported when using your plugin. All very handy.
                                            One fashion request, could you make the plugin panel a lot smaller ?
                                            SU panels and text's are a little less big. Although I use a 30" screen your panel takes a good chunck of it....
                                            Tx again
                                            Francois
                                            • 2 / 3
