    Rogue's W.I.P's!
    922 Posts 55 Posters 169.9k Views 55 Watching
    • Roguer1R Offline
      Roguer1
      A little more work...
      Find all my models on the [3D Warehouse](https://3dwarehouse.sketchup.com/user/d8bb4d13-3b01-44a0-a007-4a77a32b6433/Ben-B?tab)
        BLANK
        Awesome bonnet!
        I got half the renders up: http://picasaweb.google.com/shamscalade/RogueMilanoWIP
        Some aren't great... That's why I'm doing 16 so you can choose which ones you like and not run out of renders.
        On your comment of the Paramount render, I don't really do anything special. I just use the same lighting setup every time. If the renders turn out fine, I'm lucky. If not, then I just retouch them with Photoshop. The retouches aren't huge, it's just brightening, darkening and blurring. For example, on the Paramount renders, the headlights turned out completely black for some reason. So all I did was lighten it up a bit.
        Just tell me your procedures so I can check if they're similar to mine.
        If only the Yakuza had heard of Australia... [url=http://sketchup.google.com/3dwarehouse/details?mid=cd46471677a3e490b8f4e95477ed5df:21uuz2ul]Ford Falcon sedan conversion[/url:21uuz2ul] [img:21uuz2ul]http://lh5.ggpht.com/_DXlDhsgmn6Q/S2Qi2PU4IJI/AAAAAAAAAuE/AqSICmCNiS4/s800/Untitled-1.jpg[/img:21uuz2ul]
        • Roguer1R Offline
          Roguer1
          Those are great renders, thanks Shams!
          I was really interested in the texture application process. I have all the render settings on their default but I don't really know what to do about the textures. If you could send me some info on what types of textures you use for what ad the levels you set them at. I just seem to get very rough metal and body paints...
          • W Offline
            Wacov
            I've just starting to play around with Indigo. After a few attempts, I've settled with this render, at the max resolution the free version outputs. Finally finished, at 2000SPP! 1hr 30min.
              BLANK
              Ooooh. I actually change the metal coverage. Usually it's 0.2, I go for 0.05 or 0.01; keepin' it minimum. I don't really like the flakes - it makes it look like a tacky paintjob. Plus, the "metal" and "base" is the same (you probably did that, just mentioning it).
              You should send me your procedures so I can see what you've done.
              @wacov said:
              1hr 30min.
              Holy s**t! I feel your pain. I thought 8 mins. was far too much...
                remus
                If you think 1 hour 30 is bad i recommend you stay away from sss and cauchy b for the moment ๐Ÿ˜„
                  MrPlanet
                  You should try 45 hours straight with a failed render ๐Ÿ’š
                  I reject your reality and substitute my own.
                  • W Offline
                    Wacov
                    Lol, I probably shoulda stopped at 1 hour. But it was still a little grainy ๐Ÿ˜„
                    I could've done it in under 20 mins at a lower res, but it's just not the same... the time doesn't really bother me anyway, there are other things I can be getting on with. And Indigo's images are so perfect O_O
                      BLANK
                      Eeek, keep your horror stories to yourselves... ๐Ÿ˜ž
                      • Roguer1R Offline
                        Roguer1
                        Lol. ๐Ÿ˜„
                        Good render btw, very nice!
                        Very similar to my very old renders of my Maverick. I think I used Indigo too.
                        • Roguer1R Offline
                          Roguer1
                          Thanks for the render advice Shams.
                            MrPlanet
                            Holy **** That looks AWESOME! How much render time was there? If it was under 15min, i will be amazed ๐Ÿ˜„
                            • Roguer1R Offline
                              Roguer1
                              Here is another
                                BLANK
                                Nice! I'm still trying to work out how to make the lights "work", as if they're switched on; no success...
                                It must be. A similar render (background off; ground reflections on; 1600x1200 res.) took me 7-8 mins.
                                  JaViXP
                                  Those renders are awesome Ben!
                                  "Giving up is way harder than trying"
                                  JaViXP's Rendering
                                  • Roguer1R Offline
                                    Roguer1
                                    Well Shams, your computer was most likely just doing the render. I had quite a lot else going on at the same time as the renders so they took about 50 minutes each. I only have a single core processor so nothing super fast.
                                    Here are more renders
                                    http://picasaweb.google.com/RogueAutomotiveDesign/Other3D
                                    I'm so happy with the results
                                      BLANK
                                      Sweet renders!
                                      Oh, I see my problem. My pc is actually dual-core. It's just the RAM is below the minumum requirement. Looks like I bought the word "Vista" rather than the computer...
                                      Anyway, the Dorifto Cobra is done. Here's a screenshot of the awesomeness:
                                      Me pulling a Vaughn Gittin Jr. impression. Yes, those captions and smoke DO show up.
                                      The controls are a bit tricky. The controls on the left are inverse (S is forward; W is backward) - it's the only way I guess. I could've removed the controls on the left, but that would leave the car one-speed, thus making it harder to drift. Oh well, have fun.
                                      2009 Trojan Cobra (Dorifto Edition).skp
                                      • Roguer1R Offline
                                        Roguer1
                                        Fun game Shams. Although its a little odd without markers.
                                        Here is a little something people might be interested in:
                                        http://www.youtube.com/watch?v=sKQs9OU-Rig
                                        • Roguer1R Offline
                                          Roguer1
                                          BLAH, I'm soo board!
                                          More renders
                                          http://picasaweb.google.com/RogueAutomotiveDesign/Other3D#
                                          • alexandre skA Offline
                                            alexandre sk
                                            nice models ๐Ÿ˜ฎ
                                            • 11
                                            • 12
                                            • 13
                                            • 46
                                            • 47
                                            • 11 / 47
