    Rogue's W.I.P's!
    922 Posts 55 Posters 169.9k Views 55 Watching
    • W Offline
      Wacov
      Lookin' good!
      • Roguer1R Offline
        Roguer1
        ..a little more
        Find all my models on the [3D Warehouse](https://3dwarehouse.sketchup.com/user/d8bb4d13-3b01-44a0-a007-4a77a32b6433/Ben-B?tab)
          JaViXP
          Awesome. Same as Mr Planet - Wordless - ๐ŸŽ‰
          "Giving up is way harder than trying"
          JaViXP's Rendering
          • Roguer1R Offline
            Roguer1
            Finally finished!
            This is a modern incarnation of the one off concept from Ford. In 1970 Ford showcased the Concept along with 5 other vehicles. The model was praised and the few fans said it would be one of the most looked at cars. It was rarely photographed and was long forgotten by most. After its showing the concept was crushed as was common practice. The resulting model was the 1971 Mustang, although the original inspiration was speculated as being the โ€˜69 Shelby Mustang. This modern Milano holds many of the same design features as the original but some changes are necessary for modernization. The engine would be a 450hp supercharged V8 mounted to the same underpinnings as the 2010 Shelby Mustang. This model was requested by Wolfgang, author at http://www.ponysite.de. The base model is the Trojan Cobra GT S. Note: You can move the front lights into place and delete the covers to show them. "The Rogue Generation"
            Error 404 (Not Found)!!1
            (sketchup.google.com)
              BLANK
              I'm currently working on the renders (4/16 done). They'll be 1600x1200, but here's a preview. Now's the time to notify me for any changes (i.e lighting, colour etc) because I don't want to give my PC a hard time by making it churn out the the wrong renders.
              If only the Yakuza had heard of Australia... [url=http://sketchup.google.com/3dwarehouse/details?mid=cd46471677a3e490b8f4e95477ed5df:21uuz2ul]Ford Falcon sedan conversion[/url:21uuz2ul] [img:21uuz2ul]http://lh5.ggpht.com/_DXlDhsgmn6Q/S2Qi2PU4IJI/AAAAAAAAAuE/AqSICmCNiS4/s800/Untitled-1.jpg[/img:21uuz2ul]
              • Roguer1R Offline
                Roguer1
                Wow Shams, thatโ€™s looking really nice. I do appreciate what youโ€™re doing very much ๐Ÿ˜„
                I just got a newer version of Hypershot, letโ€™s see if itโ€™ll work now
                EDIT: Yay! It works, absolutely no problems so far! But my texturing is a little sh!t
                • Roguer1R Offline
                  Roguer1
                  Damn it! Why do my renders turn out crap! Shams, you need to show me all your settings ๐Ÿ˜‰
                    BLANK
                    I use the "whitestudio" light setup, but I turn off the background. That's about it I guess.
                    • Roguer1R Offline
                      Roguer1
                      I have tried that method but I think Iโ€™m doing the textures or render settings wrong. I have the render settings set to their defaults. Maybe itโ€™s just my cr@p processor that canโ€™t handle rendering. It seems to do the same thing no matter what program I use... ๐Ÿ˜ž
                      • Roguer1R Offline
                        Roguer1
                        A little more work...
                          BLANK
                          Awesome bonnet!
                          I got half the renders up: http://picasaweb.google.com/shamscalade/RogueMilanoWIP
                          Some aren't great... That's why I'm doing 16 so you can choose which ones you like and not run out of renders.
                          On your comment of the Paramount render, I don't really do anything special. I just use the same lighting setup every time. If the renders turn out fine, I'm lucky. If not, then I just retouch them with Photoshop. The retouches aren't huge, it's just brightening, darkening and blurring. For example, on the Paramount renders, the headlights turned out completely black for some reason. So all I did was lighten it up a bit.
                          Just tell me your procedures so I can check if they're similar to mine.
                          • Roguer1R Offline
                            Roguer1
                            Those are great renders, thanks Shams!
                            I was really interested in the texture application process. I have all the render settings on their default but I don't really know what to do about the textures. If you could send me some info on what types of textures you use for what ad the levels you set them at. I just seem to get very rough metal and body paints...
                            • W Offline
                              Wacov
                              I've just starting to play around with Indigo. After a few attempts, I've settled with this render, at the max resolution the free version outputs. Finally finished, at 2000SPP! 1hr 30min.
                                BLANK
                                Ooooh. I actually change the metal coverage. Usually it's 0.2, I go for 0.05 or 0.01; keepin' it minimum. I don't really like the flakes - it makes it look like a tacky paintjob. Plus, the "metal" and "base" is the same (you probably did that, just mentioning it).
                                You should send me your procedures so I can see what you've done.
                                @wacov said:
                                1hr 30min.
                                Holy s**t! I feel your pain. I thought 8 mins. was far too much...
                                  remus
                                  If you think 1 hour 30 is bad i recommend you stay away from sss and cauchy b for the moment ๐Ÿ˜„
                                    MrPlanet
                                    You should try 45 hours straight with a failed render ๐Ÿ’š
                                    I reject your reality and substitute my own.
                                    • W Offline
                                      Wacov
                                      Lol, I probably shoulda stopped at 1 hour. But it was still a little grainy ๐Ÿ˜„
                                      I could've done it in under 20 mins at a lower res, but it's just not the same... the time doesn't really bother me anyway, there are other things I can be getting on with. And Indigo's images are so perfect O_O
                                        BLANK
                                        Eeek, keep your horror stories to yourselves... ๐Ÿ˜ž
                                        • Roguer1R Offline
                                          Roguer1
                                          Lol. ๐Ÿ˜„
                                          Good render btw, very nice!
                                          Very similar to my very old renders of my Maverick. I think I used Indigo too.
                                          • Roguer1R Offline
                                            Roguer1
                                            Thanks for the render advice Shams.
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 46
                                            • 47
                                            • 17 / 47
