    Rogue's W.I.P's!
    922 Posts 55 Posters 188.4k Views 55 Watching
    • Roguer1R Offline
      Roguer1
      Here is an image set for the progress on the Milano
      Documents.zip
      ..here is a sample
      Find all my models on the 3D Warehouse
      • RayOchoaR Offline
        RayOchoa
        reminds me of the challenger 👍
        CaR DeSiGnS bY mE
        http://ray-ochoa.com
          BLANK
          Blasphemy! Ray's right. "Squarier" front fascia, perhaps?
          Iacocca Mustang... any thoughts? The only thing that's letting this futuristic design down is the taillights IMO. They should've went for the newer 2010 ones, or some aftermarket LEDs.
          If only the Yakuza had heard of Australia... [url=http://sketchup.google.com/3dwarehouse/details?mid=cd46471677a3e490b8f4e95477ed5df:21uuz2ul]Ford Falcon sedan conversion[/url:21uuz2ul] [img:21uuz2ul]http://lh5.ggpht.com/_DXlDhsgmn6Q/S2Qi2PU4IJI/AAAAAAAAAuE/AqSICmCNiS4/s800/Untitled-1.jpg[/img:21uuz2ul]
          • Roguer1R Offline
            Roguer1
            Wow, that’s one nice Mustang. I do very much like the Fastback body but I do agree with you about the tail lights. They need to curve inward, like the second gen Fastback...Still very nice
            Just to remind you, I'm making a modern version of a Mustang Concept, yes, it may look a bit out of place, but it’s a concept!
            • Roguer1R Offline
              Roguer1
              Update:
              -Hood ✔
              -Rear window ✔
              Hey Shams! Would you be kind enough to do some renders of this once I'm finished? I don’t have anything to do renders, the only good thing is Hypershot and it doesn’t work for me
                BLANK
                • W Offline
                  Wacov
                  Lookin' good!
                  • Roguer1R Offline
                    Roguer1
                    ..a little more
                      JaViXP
                      Awesome. Same as Mr Planet - Wordless - 🎉
                      "Giving up is way harder than trying"
                      JaViXP's Rendering
                      • Roguer1R Offline
                        Roguer1
                        Finally finished!
                        This is a modern incarnation of the one off concept from Ford. In 1970 Ford showcased the Concept along with 5 other vehicles. The model was praised and the few fans said it would be one of the most looked at cars. It was rarely photographed and was long forgotten by most. After its showing the concept was crushed as was common practice. The resulting model was the 1971 Mustang, although the original inspiration was speculated as being the ‘69 Shelby Mustang. This modern Milano holds many of the same design features as the original but some changes are necessary for modernization. The engine would be a 450hp supercharged V8 mounted to the same underpinnings as the 2010 Shelby Mustang. This model was requested by Wolfgang, author at http://www.ponysite.de. The base model is the Trojan Cobra GT S. Note: You can move the front lights into place and delete the covers to show them. "The Rogue Generation"
                        Error 404 (Not Found)!!1
                        (sketchup.google.com)
                          BLANK
                          I'm currently working on the renders (4/16 done). They'll be 1600x1200, but here's a preview. Now's the time to notify me for any changes (i.e lighting, colour etc) because I don't want to give my PC a hard time by making it churn out the the wrong renders.
                          • Roguer1R Offline
                            Roguer1
                            Wow Shams, that’s looking really nice. I do appreciate what you’re doing very much 😄
                            I just got a newer version of Hypershot, let’s see if it’ll work now
                            EDIT: Yay! It works, absolutely no problems so far! But my texturing is a little sh!t
                            • Roguer1R Offline
                              Roguer1
                              Damn it! Why do my renders turn out crap! Shams, you need to show me all your settings 😉
                                BLANK
                                I use the "whitestudio" light setup, but I turn off the background. That's about it I guess.
                                • Roguer1R Offline
                                  Roguer1
                                  I have tried that method but I think I’m doing the textures or render settings wrong. I have the render settings set to their defaults. Maybe it’s just my cr@p processor that can’t handle rendering. It seems to do the same thing no matter what program I use... 😞
                                  • Roguer1R Offline
                                    Roguer1
                                    A little more work...
                                      BLANK
                                      Awesome bonnet!
                                      I got half the renders up: http://picasaweb.google.com/shamscalade/RogueMilanoWIP
                                      Some aren't great... That's why I'm doing 16 so you can choose which ones you like and not run out of renders.
                                      On your comment of the Paramount render, I don't really do anything special. I just use the same lighting setup every time. If the renders turn out fine, I'm lucky. If not, then I just retouch them with Photoshop. The retouches aren't huge, it's just brightening, darkening and blurring. For example, on the Paramount renders, the headlights turned out completely black for some reason. So all I did was lighten it up a bit.
                                      Just tell me your procedures so I can check if they're similar to mine.
                                      • Roguer1R Offline
                                        Roguer1
                                        Those are great renders, thanks Shams!
                                        I was really interested in the texture application process. I have all the render settings on their default but I don't really know what to do about the textures. If you could send me some info on what types of textures you use for what ad the levels you set them at. I just seem to get very rough metal and body paints...
                                        • W Offline
                                          Wacov
                                          I've just starting to play around with Indigo. After a few attempts, I've settled with this render, at the max resolution the free version outputs. Finally finished, at 2000SPP! 1hr 30min.
                                            BLANK
                                            Ooooh. I actually change the metal coverage. Usually it's 0.2, I go for 0.05 or 0.01; keepin' it minimum. I don't really like the flakes - it makes it look like a tacky paintjob. Plus, the "metal" and "base" is the same (you probably did that, just mentioning it).
                                            You should send me your procedures so I can see what you've done.
                                            @wacov said:
                                            1hr 30min.
                                            Holy s**t! I feel your pain. I thought 8 mins. was far too much...
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 46
                                            • 47
                                            • 16 / 47
