    How do I create realistic wall build-ups?
    18 Posts 9 Posters 2.1k Views 9 Watching
      gclyde
      Hi Folks,
      Please refer to the link:
      (www.scotframe.co.uk)
      I am a techncial manager for a timber frame company, and I would like to create our own wall build-up visualisations - similar to the one shown in the link above.
      I would also like to be able to show off all of the components in an external wall.
      How do I go about it?
      Regards
      Gra
        Just draw it πŸ˜‰
        Sketchup is perfect for that! β˜€
          It's really just a couple of groups stacked next to (behind) each other. Then you can "destroy" them as you wish. They's all individual groups so you can edit / draw on / PushPull / paint their faces individually
          Wall.skp
          • W Offline
            watkins
            Dear Graham,
            If you want something quick and professional then you might consider placing a small contract with one our talented UK Sketchup users. I'm sure the cost would be quite low for a small job like this. This would get you where you want to be within a day or two.
            Regards,
            Bob
              dylan
              There is no easy answer other than as someone already mentioned, just model it.
              Each layer will be a seperate group.
              If you want realistic you will also have to then use a seperate rendering software and work on the materials to get it looking good.
              I did something similar a few years ago using SU and Photoshop, but it was not intended to look real, just show the roof and wall build up.
              http://forums.sketchucation.com/viewtopic.php?p=22880#p22880
              http://dmdarchitecture.co.uk/
                gclyde
                Hi Dylan,
                Yes, your details are the sort of thing that i need to produce.
                However, I was not aware of having to use another software package alongside SU.
                Gra
                  dylan
                  Gra
                  You don't have to use another package, I did only to annotate the drawing.
                  If you want a realistic look, like on the link you posted, rendering in another package will be required.
                  You can still achieve a nice look with just SU alone.
                  • Alan FraserA Offline
                    Alan Fraser
                    The Scotframe illustration is real...but it's not photoreal. About the only thing that distinguishes it from raw SketchUp output are the soft shadows between layers. That would be a relatively easy thing to achieve with a little post-processing in Photoshop.
                    Personally, I think SketchUp's illustration-type output is perfect for this kind of thing.
                    3D Figures
                      Jim
                      I actually did one based on that image yesterday, but wasn't going to post since it was for practice and not terribly nice. But here it is. Raw SketchUp - components from the 3d warehouse, and standard SU materials.
                      You basically build it as if it you were building it for real, then slice away. I used a Google's bezier plugin to draw the cut-away curves.
                      I attached the model if it might help.
                      detail1.skp
                        Alan Fraser
                        A slightly modified version of Jim's model, adapted to take a brick texture and exported directly from SU with shadows on faces but not on ground.
                        3D Figures
                          Well, it seems that you both beat my "cheap" example. 😳
                          But surely this is generally speaking the way it could be done in SU quite easily - it's just a matter of detailing and attention.
                            gclyde
                            Jim & Alan,
                            Thanks very much for the sample detail....I think that I now get the idea of how to make the section detail πŸ‘
                            Is there a way of saving the full wall build up as a template, then draw lines as a wall type?
                            Gra
                              Hi Graham,
                              You can save any file as a custom template (with any model parts in it and any kind of settings like extra layers, styles, scenes, views, used materials etc.) under File > Save as template.
                              Then if you go to Window > Preferences > Templates, you can select it as the file loaded when you open SU.
                                troyhome
                                Alan, I like your new arbiter. Could you post that brick texture?
                                IOviz.com
                                SU Pro 2024 PC
                                  gclyde
                                  Hi Gaieus,
                                  Thanks for the advice. I am still trying to get my head round SU and LO πŸ˜’
                                  I am sure that the penny will drop soon ...i can't wait 😍
                                  If only there was a tutorial covering all that i need from start to finish 😒
                                  Regards
                                  Gra
                                    dylan
                                    Graham there are thousands of tutorials out there and many on this very site.
                                    If you explain exactly which areas you wish to improve on we can point you in the right direction.
                                      gclyde
                                      Hi Dylan,
                                      Thanks for the offer of some help.
                                      Basically, I am a newbie. I have watched a lot of tutorials, but not quite there yet.
                                      I am a building engineer and want to be able to produce construction drawings. I also want to be able to produce technical tutorials/guides/animations showing how things are put together/sales literature for staff and clients etc.
                                      I have hundreds of CAD construction details and want to bring them to life using SU.
                                      Any help/direction would be warmly received.
                                      Regards
                                      Gra
                                      • E Offline
                                        ericschimel
                                        Watch this video. Its a tutorial on exactly what you want to do!
                                        -Eric
                                        http://plugin.sketchthis.net
                                        Sketchup Kitchen Design Plugin
                                        Custom Models
