    Dynamic naming?
    Scheduled Pinned Locked Moved Dynamic Components
    4 Posts 3 Posters 1.1k Views 3 Watching
      Pongo1471
      Im new at dynamic content, been following tutorials so i could make a grid of an item with equal spacing and it went well
      but im now after having a custom name on the new items created, is this even possible?
      For example, each time i scale the item the new components created are named Copy 001 Copy 002 Copy 003 ect
      id like to change it so that it dose not say Copy and has no spaces, so it just has the numbers after each one
      Is this possible? and if so could someone point out to me how please?
      Thank you for reading πŸ˜„
      • Chris FullmerC Offline
        I don't think that is possible. But I could be wrong, I'm starting to forget things about DC's.
          Pongo1471
          love the quote in your sig Chris ^_^
          well chears for the reply, gues it will have to do then
          im using the dynamic creation to help my development in building mesh's for IMVU (its simmilar to second life)
          anywhere you want furniture you need a furniture node and each needs to be named and numberd correctly, its just the same name with an increasing number, was just hoping there was something to overide the naming veriation and then just have 1++ or something in there to show thats the veriable each time to incriment
          well ill keep an eye on the thread in the hopes someone knows any different ^_^
            ladyquestio
            Well if you are only looking at furniture nodes on IMVU the just copy and paste making each one unique as you go then use Neo's plugin. It's found in the SketchUp groups down loads sticky.
            if you are wanting all types.. I am working on and having some selected people beta a plugin based on TIG's and Neo's Plugin.
            It does require copy and pasting and making unique and naming seating nodes with special coding.. but it seems to work. At least so far.. will post more info if it does work out.
            By the way that's my IMVU name too!
