    Cutout
    12 Posts 4 Posters 824 Views 4 Watching
      REDnumber5
      Hi, I've been using Sketchup for a few months and I'm looking forward to getting better at modeling and appreciate all the help offered here. Can someone tell me what the term is for cutting out a notch like this and how I might go about doing it.
      http://i131.photobucket.com/albums/p313/shawn1270_photos/cutout.jpg
        I don't know the name, but you can make that with a boolean operation ๐Ÿ˜‰ I have made that by hands so right click/ "Intersect" ๐Ÿ˜„
        More easy with a plug ๐Ÿ’š
        A plug exists at Smustard.com Booltools by Dale Martens ๐Ÿ˜‰
        [flash=480,385:2x34nxzg]http://www.youtube.com/v/umcoC1JQAFQ&hl=fr&fs=1&[/flash:2x34nxzg]
          REDnumber5
          Thank you, I was thinking about it all wrong, I'd drawn the lines and arc's and was thinking there was a way to somehow fill it in.
            The "capsule" is a cylinder + 2 half spheres
            If you want precision just draw more segments in drawing the half spheresphere.jpg
            • Jean LemireJ Offline
              Jean Lemire
              Hi REDnumber5, hi folks.
              See attached SU file for ideas.
              Curved notch.skp
                Yup but you have also a capsule soon ready and parametric inside the Skechyphysics tools' plug ๐Ÿ˜‰
                  Jim
                  Here is the first thought I had. Draw the U shape, draw a cirlce and FollowMe along the U, Intersect and delete. But I am not sure if it is the right shape. If I made the arcs the same as the circle, then I think it would be OK.
                    Seems it's not exactly the same ๐Ÿ˜‰
                      Jim
                      What if you make the arc radius 1/2 the circle radius?
                        seems that make not 90ยฐ between horizontal section and vertical section so can't be a 1/4 of sphere ๐Ÿ˜ฎsphe1.jpg
                          REDnumber5
                          So I took a 1/4 sphere and moved the endpoint to the drawn arc on the face, then scaled it to fit and moved the outside points to match, flipped, moved, pulled, intersected and deleted the unwanted lines. I could't get it to match perfectly bcause the drawn arcs had more endpoints than the 1/4 sphere, maybe with a little forethought I could specify the the amount of segments to edit exactly. Or is there a simple way too add points in the middle of a line?
                          Thanks again
                          I didn't show the inbetween steps here, I hope this makes sense.
                          http://i131.photobucket.com/albums/p313/shawn1270_photos/cutout2.jpg
                          http://i131.photobucket.com/albums/p313/shawn1270_photos/cutout3.jpg
                            Yes that makes sens ๐Ÿ˜„
                            1/4 of sphere is logical and simple but in fact you can take any variation of that, depending of what you want as angle for your cut out ๐Ÿ˜‰
                            A middle of a line? there is an hot point of the middle of a line, so redraw over start to hot point and kill the bigger ๐Ÿ˜‰
