    Animation, rotation
    17 Posts 4 Posters 1.9k Views 4 Watching
      Use the plug mover by cmd ๐Ÿ˜‰
      The more easy for animate something in SU โ˜€
      And if you want more subtle take a look at SketchyPhysics3 ๐Ÿ˜‰ by CPhillips
      But maybe not for a beginner ๐Ÿ˜„
        He wants an
        EASY way
        mover is the more easy even against the system of layer ๐Ÿ˜‰
        • GaieusG
          Hewants an
          SHEyou mean...
          ๐Ÿ˜„
            mogogirl
            LOL, thanks everyone. I will work on trying to animate my little wheel. And by EASY, I guess I meant something a newbie could understand and follow. I do understand that easy is a very relative term!
              Oh Sorry I am so confused ๐Ÿ˜ณ
              I did'nt seen the text only the problem ๐Ÿ˜ณ
              http://www.samourais-et-ikebana.com/images/art/ikebana/rikka2.jpg
              • GaieusG
                Hehe... No, me sorry, Pilou; it was a "cheap" revenge from me.
                And the flowers are very gentle from you, I hope Mary can make that animation after all this.
                ๐Ÿ˜‰
                  mogogirl
                  Arrrgh! this is all making me feel like such an idiot!!!!! I have made the array but can not for the life of me figure out how to put the copies onto layers. I'm just not getting this. I've watched the video on youtube about layers and I don't seem to understand. I understand the concept of what to do, just not HOW. Am I making this too hard?
                  I'm such a visual person, I need someone to show me how to do this and then I can figure it out. Trying to do this from written instructions is just driving me crazy! Oh well, I'll keep trying and maybe I'll eventually figure this out.
                    Of course you have remarked when you have increased the time of the scene transition (Model Info/animation)
                    the object makes some foolish rotations ๐Ÿ˜ฎ
                    Why? It's because Group has a bad axes!
                    So for rotate an object you must use "Component" and give it his own axis of rotation !
                    (not possible for a group)
                    All will works fine with that! โ˜€
                    For just translation groups are sufficient ๐Ÿ˜„
                    And don't forget
                    Select scene
                    Select group (or component for rotation)
                    Move it (or rotate it)
                    Remember position of selection(all the time this is not made of forgotten)
                    If you want you can make anything else zoom move rotate the scene
                    Update scene
                    Select scene...etc
                    Ps As said in the text help you can't save the animation, so you must record the animation screen by prog like Camstudio (free) or similar!
                    Have fun animating ๐Ÿ˜Ž
                      Hello Mogo girl ๐Ÿ˜‰
                      The layer method is some painful ๐Ÿ˜‰ mover.rb is the one ๐Ÿ˜‰ (but see next post after reading this one!)
                      Some thing like this?
                      With only 3 scenes you will have perfect rotation ๐Ÿ˜‰
                      (I don't know who is the author : lines follow are from cmd)
                      How To Use:
                      • Place the mover.rb and the mover_extensions folder into the Plugins directory
                      • The position of the components (position and orientation of the component axis) are tied to the scene.
                      1. Create your scenes
                      2. Engage the 1st SketchUp Scene where you want the animation to start
                      3. Select your component/s you want to animate and place them in the needed position and orientation. While they are selected go to Plugins > "Remember Position of Selection"
                        The position of the selected components will now be tied to that specific scene.
                      4. Repeat Step 2 for the following scene.
                      When you are finished, when you click on each scene, the models will automatically transition.
                      Note:
                      • If you scale the component, you may see some strange animation transitions. Be sure to "scale definition" to correct the problem.
                      • You will not be able to export this animation through SketchUp. If you try, the components will remain stationary.
                      rotate.skp
                      • GaieusG
                        @mogogirl said:
                        ...I have made the array but can not for the life of me figure out how to put the copies onto layers...
                        Right click > Entity info > and change the layer there. Of course, you need to have the layer already created.
                          mogogirl
                          By George, I think I've done it!!!!! I need a few adjustments before I publish it here for you but I will try to have that done later today. It's not brain surgery...but I sure am proud of myself...lol. I'll let you know as soon as I have a decent animation to show.
                            What a suspense! ๐Ÿ˜„
                            What method was used: that is a terrible wait ๐Ÿ’š
                            • GaieusG
                              Cool,Mary. You only need to grasp the concept once and from then on, it will seem to be easy. Such "layered and scened" animations are always a bit of a hasle however so once you understand the logic, you may really wish to look into plugins that automate and make this process easier.
