    Barcelona Pavilion
    29 Posts 24 Posters 30.3k Views 24 Watching
      ScottPara
      Great renders. My only comment would be a real barcelona's cushions are at least twice as thick as those.
      Scott
      Love the fact that some HATE my avatar.....
      • soloS
        Fantastic renders, great attention to detail and mapping of textures. Definitely one for the halls of fame.
        • ely862meE
          ely862me
          :wow: u got my attention,very nice..bravoo
          Elisei (sketchupper)
          Come and See EliseiDesign
          • K
            kwistenbiebel
            Hi Jackson,
            very nice results! 👍
            You are using Vray for Max?
            I ask that because I see direct sun light and HDR light together in 1 image.
            VrayforSU has a problem doing that.......or did you find a solution for that?
              Jackson
              Thanks Kwist!
              All done with VRay for SU- I use the same solution we discussed once on the ASGvis forums with the following parameters:
              GI map Multiplier 40
              Blend Ratio 0.99
              Texture A: VRay Sky/Sun with an Intensity Multiplier of 0.4
              Texture B: Black ground to White sky gradient spherical map jpg (i.e. LDRI), just 200 x 100 px made in Photoshop with a Multiplier of 1.
              I found even such a simple LDR gradient GI map really helps bring out the details in the external areas, especially the statue by providing 360° fill light to counteract VRay's somewhat overly-simple sky and sun GI. The crazy 0.99 blend ratio is required as the VRay sky is so massively powerful compared to LDRI or even HDRI GI maps- I've even had to take to down to 0.999999 for a couple of projects.
              Jackson
              • K
                kwistenbiebel
                Thanks for explaining....I will need to convert the multiplier values to V1.0 as I still prefer using that version.
                  ScottPara
                  Jackson,
                  Here is a picture directly from the Knoll Studio website. This should clear things up.
                  Maybe not twice as thick but noticeably thicker in the original.
                  Scott
                  • W
                    Wacov
                    This is INCREDIBLE 😲 Some of the best renders I've ever seen!
                      MrWip
                      A really great work Jackson... congratulations ! ...we all have to work harder and harder to keep on being able to show things here without being ashamed !
                      Just a little remark, the level of detail of the travertine on the ground is maybe a bit weak regarding to the quality of the metal standing next to it... maybe a really soft displacement could bring more realisme to the surface on a close up view.
                      http://www.wip-archi.com
                      • david_hD
                        david_h
                          dylan
                          Wow Jackson, I find these renderings amazing!
                          I didn't realize you was this good 😉
                          You have certainly got the hang of Vray!
                          The second and forth images of the first post I love (i love them all, but these are my favourite). The metalwork and glass is exqusite 👍
                          http://dmdarchitecture.co.uk/
                          • EdsonE
                            Edson
                            bravo, jackson. great work indeed. it reveals your already known attention to detail.
                            http://www.mahfuz.arq.br
                            • P
                              princedragoncok
                              Great work, congratulations 👍
                              • N
                                notareal
                                Great work!
                                • olisheaO
                                  olishea
                                  i cant even tell what's real and what's render anymore!
                                  oli
                                  • holmes1977H
                                    holmes1977
                                    AMAZING
                                    Thanks Jackson for including your settings
                                    Keep them images coming
                                    Exaggeration makes a dull story better.
                                    • C
                                      CameronVan
                                      Beautiful work Jackson. Thank you for sharing your images and your settings.
                                        Jackson
                                        Thanks for all the kind comments! 😄
                                        I left my laptop rendering again last night and the result is another 4 renders, concentrating on details and a view of an internal corner you don't often see in photo sets of the pavilion.
                                        The column foot detail has been pretty heavily photoshopped as the travertine slab diffuse map doesn't really stand up to close inspection, so I PSd a higher resolution example in and mapped it over the rendered one. The others have just been gamma and exposure adjusted from the HDR renders, a little diffuse glow and a little dodging on the stool cushion seams. The last one shows window frames without any filleting, beading or screws- I'll update that part of the model one day, but I thought it might be interesting to post an example of the difference that details like that can make to a render.
                                        Scott, re: the chair and stool cushion thickness, on studying more photos I agree they could be a bit thicker (uuugh, back to the vertice mines LOL 😆 ), but it's only on copies that I've seen cushions anywhere near twice as thick as in my model, see the black copies below compared with the real deal. I really had my heart set on modelling the original original barcelona furniture with bolted steel legs rather than Mies' updated cast monolithic ones that we all know and love, but I couldn't find reference photos anywhere. I'm pretty sure I remember seeing them at the Bauhaus museum in Berlin years ago- I'm going back in September so I might have to sneak my camera in. heh heh 😕
                                        http://i449.photobucket.com/albums/qq215/JacksonPhotobucket/FakeBarcaChair.jpg
                                        http://i449.photobucket.com/albums/qq215/JacksonPhotobucket/RealBarcaChair.jpg
                                        Again, the original 1400 x 800 images can be viewed at the following links:
                                        http://i449.photobucket.com/albums/qq215/JacksonPhotobucket/7_29BarcelonaPavilionInterior090-1.jpg
                                        http://i449.photobucket.com/albums/qq215/JacksonPhotobucket/8_29BarcelonaPavilionInterior090-1.jpg
                                        http://i449.photobucket.com/albums/qq215/JacksonPhotobucket/9_29BarcelonaPavilionInterior090-1.jpg
                                        http://i449.photobucket.com/albums/qq215/JacksonPhotobucket/10_29BarcelonaPavilionInterior09-1.jpg
                                        http://i449.photobucket.com/albums/qq215/JacksonPhotobucket/7_29BarcelonaPavilionInterior090617.jpg
                                        http://i449.photobucket.com/albums/qq215/JacksonPhotobucket/8_29BarcelonaPavilionInterior090617.jpg
                                        http://i449.photobucket.com/albums/qq215/JacksonPhotobucket/9_29BarcelonaPavilionInterior090617.jpg
                                        http://i449.photobucket.com/albums/qq215/JacksonPhotobucket/10_29BarcelonaPavilionInterior09061.jpg
                                        Jackson
                                        • 2 / 2
