    Where lies the bug?
    24 Posts 8 Posters 4.5k Views 8 Watching
      @adamb said:
      Yeah, I came across this too. Looks like SU (very naughtily) stores the scale in the W component of the 4th column. Its typically 1.0, so I guess they thought nobody would notice! So you need to set it to 1.0 explicitly.
      But then I need to scale up all the other values as well, right? If I didn't wouldn't I end up with a completely misplaced entity?
      @adamb said:
      Also check you 3 axes are all at right-anglers to each other (orthogonal). Your numbers above look good eg 1.414.. is square root of 2.0 (good) and then its 0.707.. which is reciprocal 2^0.5
      Isn't this an rounding issue for when it converts the units to strings? The script only rotates and uniformly scales - so it shouldn't mess with the axis. (unless there's some underlying mechanism I'm not aware of?)
        I seem to have found a work around, normalizing the Scale transformation t_scale:
        t_scale = Geom::Transformation.scaling(@reference_point1.position, scale) ts = 1 / t_scale.to_a[15] ta = t_scale.to_a.collect { |d| d * ts } t_scale = Geom::Transformation.new(ta)
        Still, it'd be good to know what's really going on. And is there a better way to normalize the transformation.
        I wonder if there's other plugins that might cause this problem with VfSU...
        • AdamBA
          AdamB
          Thats not going to work generally. What if I scaled by 2.0 in X, 5.0 in Y, and 8.0 in Z?
          Just forget the SU hack of storing stuff in t[15]. Overwrite it with 1.0..
          The 4x4 matrix you get back is really 4 vectors each of 4 elements laid out as:
          [x axis direction and length, 0]
          [y axis direction and length, 0]
          [z axis direction and length, 0]
          [origin , 1]
          The last (4th) element of each is to all intents, not used.
          BTW If you want to remove all scaling from matrix you need to make the length of each of those axes = 1.0
          If t is the Geom::Transformation, then using the methods t.xaxis you get back a normalized vector.
          m[0] = t.xaxis[0] m[1] = t.xaxis[1] m[2] = t.xaxis[2] m[3] = 0 m[4] = t.yaxis[0] m[5] = t.yaxis[1] m[6] = t.yaxis[2] m[7] = 0 m[8] = t.zaxis[0] m[9] = t.zaxis[1] m[10] = t.zaxis[2] m[11] = 0
          gives you the transform with all scaling removed but leaving the rotation.
            For the purpose if the RotaScale plugin - it's all uniformly scaled.
            I'm not that familiar with this transformation matrix. And I'm not sure if I understand what you're saying here. If I just override t[15] to 1.0 I loose all scaling.
            I actually do want the scaling.
            • AdamBA
              AdamB
              Its meant to be 1.0 Its actually wrong not to be 1.0 but since the matrix is used for 3D and not 4D, they "get away with it".
              Aren't we going around in circles here? The blah.transform.to_a gets the correct transform for blah. I use it all the time in LightUp and it works fine. The only thing is, SU stores some uniform scale info in m[15]. If you want to apply this uniform scale then you could do:
              m[0] = t.xaxis.length=m[15] ... ...
              Perhaps its worth explaining that the scale of each axis is represented in the matrix as the length of the axis vector. So when you have X axis pointing along 1,0,0 and Y along 0,1,0 and Z along 0,0,1 then changing the length of those vectors becomes making those '1' the scale_factor, hence you'll see code that sets the diagonal of the matrix to scale_factor as Pixero suggested.
              Adam
              • fredo6F
                Tom,
                Sorry to pop up in this. I may have missed something.
                Do you wish to rotate and scale individual cubes (which is what I guess), or the whole selection?
                  Tom,
                  Whole selection. In regards to the RotaScale plugin: http://forums.sketchucation.com/viewtopic.php?f=180&t=19199
                  The plugin works, in SU at least - but the problem is that VfSU doesn't read the transformation of the groups/components properly. So the transformation data needs to be converted into the same as it would if you'd use native SU tools.
                  • scottliningerS
                    scottlininger
                    Thom,
                    Can you filter the weirdness down to a few lines of Ruby and post? Sounds like SketchUp is using one unused cell of the transform matrix to store some scale information. I have no idea why, but there's probably a legacy reason for it.
                    • Scott Lininger
                      SketchUp Software Engineer
                      Have you visited the Ruby API Docs?
                    • P
                      Pout
                      we had a similar thingie with rotation an object in AutoCAD and then exporting it to VRML.
                      I see if i can get a descent answer from a developer
                        http://forums.sketchucation.com/download/file.php?id=28725
                        In this screenshot the two cubes are of the same definition. The large one is roated 45 degrees and scaled x2.0 manually.
                        .transformation.to_a returns this for the manually rotated and scaled box:
                        [1.4142135623731, -1.4142135623731, 0.0, 0.0, 1.4142135623731, 1.4142135623731, 0.0, 0.0, 0.0, 0.0, 2, 0.0, -16.3076205658699, 55.6776993060274, 0.0, 1.0]
                        If I then RotaScale the small box to fit the large one .transformation returns this:
                        [0.707106781186548, -0.707106781186548, 0.0, 0.0, 0.707106781186548, 0.707106781186548, -0.0, 0.0, 0.0, 0.0, 1.0, 0.0, -8.15381028293495, 27.8388496530137, 0.0, 0.5]
                        Every value of the RotaScaled component is half of the manually scaled and rotated component.
                        In Sketchup everything looks fine. But when I render RotaScaled groups/component with V-Ray they don't match.
                        http://forums.sketchucation.com/download/file.php?id=28705&t=1
                        What it looks like is that the scaling transformation I make is stored scaled down in the matrix and that this is indicated in the last (15th) array value. I've reported this to ASGVis.
                        Question is, is this suppose to be like this?
                        • 2 / 2
