    What's Up?
    18 Posts 9 Posters 1.7k Views 9 Watching
    • marked001M
      marked001
      this is very cool.... i want to think the puddles should maybe be darker? like the concrete is soaked with water?
      http://www.revision21vis.com
      instagram: revi21on
      • boofredlayB
        boofredlay
        Nice job! where are the puddles coming from though? I'd put some wet spots on the stairs, or on the ceiling above to puddles, just so they don't look like they appeared out of nowheres πŸ˜„
        Thanks.
        Well there is a peeled back panel above the far puddle.
        Good tip. I would not have thought of that.
        • boofredlayB
          boofredlay
          Update.
          • olisheaO
            olishea
            good stuff boo
            the puddles seem a little too unnatural, I cant put my finger on it. They seem viscous somehow. whats this image for btw?
            oli
            • DanielD
              Daniel
              Looks great, Eric.
              My avatar is an anachronism.
              • marked001M
                marked001
                @olishea said:
                good stuff boo
                maybe if the actual texture is painted to be a little darker..then extend the darkness/wetness a bit beyond the puddle? might help 'ground' it.
                instagram: revi21on
                • boofredlayB
                  boofredlay
                  Thanks again guys. Daniel, it is hard to see but the graffiti in the middle right says Daniel πŸ˜†
                  Also, I made The Daily CatchUp as the "tossed" newsprint to the lower left. I think leaving it out would help the image however.
                  Again, great tip about the wet Jason. I might try it soon.
                  Oli, this is just for practice. I wanted to see if I could create this type of mood purely with Podium and no post processing. I got the idea from a piece of artwork I saw recently. I might try it with Vray next.
                  • G
                    gasher
                    These look great I have 0 rendering experience, yet, so my comment comes with no expertise.
                    It seems the nearest puddle is sitting above the level of the concrete as opposed to having the liquid flow into the depression it would find on an unlevelled surface. I think the added 'viscosity' is related to the reflected light coming from the closest puddles near left edge, as opposed to it sitting level with the concrete. Maybe the water that would flow through this space would have some added grit and be 'less clear' after seeping through the ground or running off down the stairs... not sure if that would effect how natural the water looks to the eye...
                    These are mere observations as I have no clue how you can change it πŸ˜„
                    Maybe I should start reading a rendering manual...
                    • boofredlayB
                      boofredlay
                      Great suggestions once again.
                      Here are a couple more. I made a depression in the pavement rather than have the water on top. Much better, thanks. And I got rid of that CatchUp Newsprint lower left πŸ˜‰
                      Also, I noticed on my work machine that the image was much darker than on my home machine and much of the detail was lost. So the second one is lighter, same image just lighter.
                      Let me know what you think.
                      • G
                        gasher
                        I really think that near puddle looks great. Well done! πŸ˜„
                        Actually I think the whole image looks great...
                          Sir
                          the lighter one is defo the better image, gives the impression theres some light from behind the observer and that they're close to the other side of the underpass too.
