    [REQ] Reverse curve script
    11 Posts 2 Posters 2.0k Views 2 Watching
      You mean the order the edges appear? That start edge becomes end edge?
      Or is it related to the shape of the curve?
      • PixeroP Offline
        Pixero
        Reversing the vertices order.
        I'm trying to animate using curves and some of them are reversed which makes the camera look backwards. πŸ‘Ž
        The secondary script is to put a construction point at the beginning of a curve for easy finding the reversed curves.
        "Mark curve start point" or something like that.
          Here's some code snippets
          curve = some_curve_object # fill in what you need
          # Reverse points in a curve
          points = curve.vertices.reverse.collect { |vertex| vertex.position }
          # (!) You want to delete the curve from the model at this point. How you do this depends if you need to consider attached faces.
          Sketchup.active_model.active_entities.add_curve(points)
          # Construction point at start
          Sketchup.active_model.active_entities.add_cpoint(curve.vertices[0].position)
          • PixeroP Offline
            Pixero
            I've tried the construction point at start but that didnt work as expected. Sometimes puts it at first vertice but other times in the middle of a curve. Hmmmm. πŸ˜•
            Here is the code I used:
            Sketchup.active_model.active_entities.add_cpoint(Sketchup.active_model.selection.vertices[0].position)
            BugExample.skp
              Oh.
              I assumed that the vertices returned where in order. That means none of my examples works... 😞
              Maybe a sorting routine that starts with the starting edges and traverses the connected edges is required....
                Or maybe not.
                That sample code line you used didn't work for me.
                Error is here:
                Sketchup.active_model.active_entities.add_cpoint(Sketchup.active_model.%(#FF8000)[**selection.vertices[0]**].position)
                corrected version that appear to work:
                Sketchup.active_model.active_entities.add_cpoint(Sketchup.active_model.selection[0].curve.vertices[0].position)
                • PixeroP Offline
                  Pixero
                  Yes thanks that seem to work.
                  Now if only I can reverse them...
                    My example doesn't work?
                      # Get the Curve object from the selection
                      curve = Sketchup.active_model.selection[0].curve
                      # Erase the original curve
                      curve.parent.entities.erase_entities(curve.edges)
                      # Rebuild it
                      • PixeroP Offline
                        Pixero
                        Thanks, it works fine now.
                        I have attached the script if anyone else needs it.
                        Now off to fix those troublesome animation curves...
                        reverseCurve.rb
