    [Plugin] [CityGen] - Core [WIP] (0.1.3a) — 19 September 2009
    109 Posts 23 Posters 92.2k Views 23 Watching
      @kwistenbiebel said:
      Will the CityGen plugin also take into account DWG imports to start form? I can imagine that it could automate the process a little so we easily can generate the 'city' surroundings and then start finetuning the buildings to reality. It would be cool if street furniture (street lights, road textures with markings etc...) would be implemented as well in a later phase....but maybe that's dreaming 😄
      That will depend on the module.
      I'm currently working on the Street Generator. It takes the centre lines for the streets and generate faces given a width. DWG plans usually includes such a centre line, so there is a potential it can be used.
      However, currently everything has to be planar. No 3D road maps. Also, it assumes a symmetrically placed centre line. It doesn't take into account the centre line in relationship to the edge road lines which you get in DWG files. Working out that is much more complex and would be something further down the line. Most likely a separate module to process DWG plans.
      As for building, I'd think that'd be possible, taking the footprint and extruding it. It's easy if the footprints are fully connected. I often find that lots of time the data I get from DWG plans have lines with gaps. Working out such a plan instantly makes it more complicated. Also, if you want something that can take the foot print and extrude it to the correct height, that's also something that will make it even more complicated.
      I'm not sure how accurate you where thinking?
      First and foremost this project will start out simple. Getting a simple way of quickly populating a city area. Illustration is the key word here, not simulation. But I work in an architectural office myself as a modelmaker and illustrator, so tools to generate geometry from DWG plans is something that is in my own interest. I certainly hope this can develop into something that could make good use of DWG data. This is after all a very open project with the intention that anyone can add their own module to build upon the existing work.
      My main concern about DWG data is that I find so much of it inaccurate. That you'd need to 'understand' the data it has and interpret it.
      Entourage and Textures are two likely separate modules. Both which of interests me once we've got the basics going.
        We should keep close in mind how the API for the communication between the modules should be. I think this is very important to get established as early as possible. But lets see how this thing evolves.
          sepo
          gingerly 😄
          Thom could you please explain how the plugin decides the radius of join between 2 roads. It would be good to have some sort of control over it so it can be used in real situations rather than purely for visual/game stuff. I have not install it yet so I might be shooting blanks here. 😉
            Close, but still not 100% the correct thread. This is the Core thread. Not the Street Generator. 😉
            (I had a feeling making all there threads would be confusing. But how would you avoid confusion of the discussion on all the modules where in one thread? ❓ Someone got a suggestion to how we can do this?)
            (I'll post the answer in the Street Generator thread sepo. 😉 )
              Small update: Added version constant to the core module so it can be identified by the modules.
                Jernej Vidmar
                I am affraid that forum is not the best option to collaborate on project like this... at least not in the long run. I do not want to turn you away from SketchUcation forum, which is great to discuss things, yet it does not provide (nor does any other forum) things like version control, task tracking, ... which you will definitely want. Maybe you shuould consider something like GitHub, which seems to be very popular choice for OS projects these days? It can make collaboration on project like CityGen much more manageable and easy...
                • Chris FullmerC
                  I think that is a good suggestion. I don't want to take the conversation away from here (where the creative juices freeloy flow), but at the same time, I"m afraid that realisticly, the logistics of working colaboratively on this will get tricky quickly - until Google Wave gets implemented in the near future!
                  But for now, perhaps a code hosting place might be necessary. What about Google Code?
                  I've created a test account. I'll add both Remus and Thoms as project owners so you can log in and test it out if you'd like. PM your emails addresses.
                  Error 404 (Not Found)!!1
                  (code.google.com)
                  • Chris FullmerC
                    OK, I got Remus signed up, but I need a gmail account from you Thom (or youll have to create it first before you can sign in and use the project admin).
                    This is just a test. To see if its something we want to try to use. It only offers opensource licenses. So PM me your gmail address and I'll add you.
                      Yea... I was thinking that some version management (and possible project management) would help us here. But I've never done such a collaboration project, so I wasn't sure what I was looking for.
                        I see SourceForge often used, anyone had any experience with that? http://sourceforge.net/
                        • Chris FullmerC
                          I download from there, but I've never used it before. I've never used any before really. So I'm open to pretty much anything, especially free 😄
                          • troyhomeT
                            troyhome
                            I don't know about coding at all, and I appreciate this ruby very much. I am
                            "into" urban design and wonder if there is a way to select different streets for different widths- for example main streets and alleys will have different widths... ?
                            Thanks for this collaborative effort!
                            IOviz.com
                            SU Pro 2024 PC
                            • tbdT
                              tbd
                              I suggest http://www.github.com or http://www.bitbucket.org - both have distributed version control (github - git and bitbucket - mercurial) and issues management
                              or we can use http://code.google.com/p/support/wiki/GettingStarted (it has support for mercurial as well)
                              http://plugins.ro
                              • Chris FullmerC
                                I know nothing about how the different distribution tools work. I've heard of subversion before, but never the onther ones. Do you prefer mercurial TBD?
                                • tbdT
                                  tbd
                                  yeah, Mercurial is my main version control (all my projects are in mercurial), but I also use git from time to time.
                                  Mercurial on Windows is smaller and faster on small sized projects that git. I also like the commands more 😉
                                  http://hgbook.red-bean.com/read/ - the book about mercurial with examples
                                  http://plugins.ro
                                    Jernej Vidmar
                                    We use Mercurial for Modelur development, too. It's great and provides GUI for windows - TortoiseHg.
                                      Are any of these free services?
                                        Yes. I'm working on that. 😉
                                        • Chris FullmerC
                                          Crazy, I had no idea there were so many options! I really appreciate you guys with experience helping point us in the right directions. I'll dig around the ones you have listed and see if I come to any conclusions (not likely 😄 )
                                            Jernej Vidmar
                                            If you decide to go with Mercurial, bitbucket free version offers 150Mb of space. As mentioned, github is free for open source projects and it offers 300Mb of space. You can use Hg-Git plugin to use Mercurial for version control. I never tried it, though. Maybe the Git itself is good choice (the man behind it is Linus Torvalds...)?
                                            Or you can go free with Google code (it uses both Subversion - you can use tortoise if you want GUI frontend and Mercurial for version control), or Sourceforge or something similar...
                                            • 1 / 6
