    Help....Please...
    27 Posts 6 Posters 2.8k Views 6 Watching
      JaViXP
      I have the same issue, and I can only make my own models (not download)... CPhillips, maybe it is 'cause it isn't saved in the HDD, as I understood.
      "Giving up is way harder than trying"
      JaViXP's Rendering
        MrPlanet
        Chrome always saves and then opens.
        I reject your reality and substitute my own.
          JaViXP
          Something good happened, download Hobbnob's tank and turn hidden geometry on, delete the two rear hidden boxes, turn hidden geometry off. Play the animation, it works. πŸ˜„
          JaViXP's Rendering
            MrPlanet
            JaViXP, go to Window>Outliner, and double-click all the objects names'Group', then, when you get to an empty one, click on the background to get the SP working πŸ˜„
              JaViXP
              I am going to try it now, thanks!
              JaViXP's Rendering
                JaViXP
                Thank you! Now it works!
                Well... To be honest I didn't do anything and it worked πŸ‘
                JaViXP's Rendering
                  Physicsguy1
                  The code might not get rid of the problem forever, but at least you can download and play other models
                    Physicsguy1
                    Mr. Planet's problem has been fixed. I was able to help Mr. Planet locate the "empty group" using the outliner, and i was able to fill that group using ruby code. This may work for Javixp. You must find the name of the group, which in this case was "----". simply put this code into the ruby console.
                    ----.entities.add_line([[0,0,0],[1,1,1]])
                    the '----' should be the name of the empty group.
                    Thanks to CPhillips for pointing out to me that it was indeed an empty group. And thanks for showing me how to make a group using ruby. i was able to decipher the code and i figured out how to put something in a certain group by specifying the name of the group. By locating the group's name, i could easily fill it. Problem Solved.
                      JaViXP
                      Yeah, I downloaded your "Scripting Fun" and it didn't work, but I opened the Outliner and it did... πŸ˜„
                      JaViXP's Rendering
                        CPhillips
                        Ok. We finally have a clue about this. But I still cant figure out the problem. When I load the simitar model and look in the outliner I cant find a group that doesnt have anything in it. Did you fix the model?
                        I need a model that fails so I can find out why it doesnt fail for everyone. Then I will be able to sleep nights.
                          Physicsguy1
                          I don't believe that the scimitar had a model error. Mr. Planet's problem was caused by the plugin, loft(chris fullmer). I'm not sure why, but Mr. Planet sent an error report. I'm not sure if JaViXP's problem was caused by loft, though. All I know is that there is something that creates an empty group.
                            MrPlanet
                            Here you go Chris, hope it helps (Model by Platypus5, i just added an empty group.)
                            M1 Gustav.skp
                              JaViXP
                              CPhillips:
                              Same, in the outliner I don't find any "empty" group, I just opened Outliner and it worked. πŸ˜„
                              PhysicsGuy:
                              That's it! Simple Loft by Chris Fullmer! (That's the plugin that broke SP, I have this plugin too).
                              JaViXP's Rendering
                                MrPlanet
                                @javixp said:
                                CPhillips:
                                PhysicsGuy:
                                Why did you repeat something Physicsguy already said. Anyway, outliner may have deleted that group (I believe it checks each one) due to it having nothing in it.
                                  MrPlanet
                                  BTW, the group is called 'Group' and it's at the bottom of all objects names group.
                                  • 2 / 2
