    Help....Please...
    27 Posts 6 Posters 3.6k Views 6 Watching
      MrPlanet
      When i downloaded the controller commands, it worked, now though, SP just stopped working. and i use Chromium (By Google).
      I reject your reality and substitute my own.
      • P
        phy
        Can you make your own models. Or did sketchyphysics just quite working absolutely.
        Tableau de comparaison de Staxyn s'agit d'un mะ“ยฉdicament uniquement sur ordonnance.
          MrPlanet
          I can make my own, but whenever i save or open a model, it does an error.
            JaViXP
            I have the same issue, and I can only make my own models (not download)... CPhillips, maybe it is 'cause it isn't saved in the HDD, as I understood.
            "Giving up is way harder than trying"
            JaViXP's Rendering
              MrPlanet
              Chrome always saves and then opens.
                JaViXP
                Something good happened, download Hobbnob's tank and turn hidden geometry on, delete the two rear hidden boxes, turn hidden geometry off. Play the animation, it works. ๐Ÿ˜„
                JaViXP's Rendering
                  MrPlanet
                  JaViXP, go to Window>Outliner, and double-click all the objects names'Group', then, when you get to an empty one, click on the background to get the SP working ๐Ÿ˜„
                    JaViXP
                    I am going to try it now, thanks!
                    JaViXP's Rendering
                      JaViXP
                      Thank you! Now it works!
                      Well... To be honest I didn't do anything and it worked ๐Ÿ‘
                      JaViXP's Rendering
                      • P
                        Physicsguy1
                        The code might not get rid of the problem forever, but at least you can download and play other models
                        • P
                          Physicsguy1
                          Mr. Planet's problem has been fixed. I was able to help Mr. Planet locate the "empty group" using the outliner, and i was able to fill that group using ruby code. This may work for Javixp. You must find the name of the group, which in this case was "----". simply put this code into the ruby console.
                          ----.entities.add_line([[0,0,0],[1,1,1]])
                          the '----' should be the name of the empty group.
                          Thanks to CPhillips for pointing out to me that it was indeed an empty group. And thanks for showing me how to make a group using ruby. i was able to decipher the code and i figured out how to put something in a certain group by specifying the name of the group. By locating the group's name, i could easily fill it. Problem Solved.
                            JaViXP
                            Yeah, I downloaded your "Scripting Fun" and it didn't work, but I opened the Outliner and it did... ๐Ÿ˜„
                            JaViXP's Rendering
                            • C
                              CPhillips
                              Ok. We finally have a clue about this. But I still cant figure out the problem. When I load the simitar model and look in the outliner I cant find a group that doesnt have anything in it. Did you fix the model?
                              I need a model that fails so I can find out why it doesnt fail for everyone. Then I will be able to sleep nights.
                              • P
                                Physicsguy1
                                I don't believe that the scimitar had a model error. Mr. Planet's problem was caused by the plugin, loft(chris fullmer). I'm not sure why, but Mr. Planet sent an error report. I'm not sure if JaViXP's problem was caused by loft, though. All I know is that there is something that creates an empty group.
                                  MrPlanet
                                  Here you go Chris, hope it helps (Model by Platypus5, i just added an empty group.)
                                  M1 Gustav.skp
                                    JaViXP
                                    CPhillips:
                                    Same, in the outliner I don't find any "empty" group, I just opened Outliner and it worked. ๐Ÿ˜„
                                    PhysicsGuy:
                                    That's it! Simple Loft by Chris Fullmer! (That's the plugin that broke SP, I have this plugin too).
                                    JaViXP's Rendering
                                      MrPlanet
                                      @javixp said:
                                      CPhillips:
                                      PhysicsGuy:
                                      Why did you repeat something Physicsguy already said. Anyway, outliner may have deleted that group (I believe it checks each one) due to it having nothing in it.
                                        MrPlanet
                                        BTW, the group is called 'Group' and it's at the bottom of all objects names group.
