Hiding facets in an imported CAD file
When I import a CAD file into SU, the curves are facetted. The same effect happens with an exploded curve in SU. I don't believe there is a way to re-constitute the curve, which is okay. What I am trying to do is hide the facets that are generated in the model. Granted it is an aesthetic thing. I can select and hide each facet but this can become quite laborious. I know I can hide edges in Styles, maybe that is my solution. But is there a way to select these facetted edges as a group and hide them?
Thanks in advance for any feedback.
Tim
I'd rather soften them than hide (in 3D I mean - so that you get a smooth surface rather than a faceted one). If you select all then right click > Soften/smooth edges, a dialog pops up where you can set the slider to your needs.
Or am I misunderstanding something?
Perfect, thank you Gaieus. That is exactly what I was looking for.
Tim
Cool, I wasn't sure if I got the problem right. A couple of further tips/info:
When you just hide the edges, they will still separate the facets i.e. you can select them individually and the whole surface will look faceted.
With softening the edges, you'll end up with a curved surface which is still made up of these facets but SU displays it as one,smooth area. The only place it is obvious that it's also made up of these facets is the edges/sides of these surfaces (say the top and bottom of a cylinder).You can manually hide edges by using the Shift + Eraser tool and soften them with the Ctrl+Eraser tool.
Smooth surfaces cannot be PushPulled, the texture cannot be positioned on them and some other limitations also apply. You can however reveal the dividing edges (and perform some of these operations) by going to View > Hidden geometry (it will also reveal other hidden things, not only softened edges).
Etc. etc...
Etc. etc...
Now that you mention it, I do remember the trick with the eraser. I just had not thought of the smoothing as a solution. Thanks again for the tip.
