    How about a ruby to apply a 3D texture/component?
    27 Posts 9 Posters 2.5k Views 9 Watching
    • Chris FullmerC
      I think about this idea everyday. If I ever get good enough with this Ruby thing, this is one that I won't need to be reminded to make.
      Its very high on my wish list! In fact, this idea is where shape bender came from - the idea of warping something existing to match a different form. I just need to get it to work 3 dimensionaly, instead of just 2.
      • AdamBA
        AdamB
        About 10 years ago I worked on a technology I called "Geometric Textures". The idea was that you associate some geometry with a UV space and then model as normal using regular textures.
        However, when you come to render, the UV coordinates for those regular textured faces are used to generate surface geometry to add true depth relief.
        So as textured facade looks like this:
        But gets rendered like this:
        It didn't take the world by storm though. ;-(
        Adam
          Oooh... automatic displacement mapping...
          So, did it not turn into anything?
          • AdamBA
            AdamB
            We did a 3dsmax plugin and some demos for PS2 but the lesson I learnt was you can't ask people to change their workflow lightly.
            I should add that this is all done "on the fly" as the realtime polygons are rendered, not some model bloating process.
            But frankly I'd use a parallax shader nowadays anyway. Not quite as good but you can do it on the GPU.
            Adam
            • EarthMoverE
              EarthMover
              You guys have to stop distracting Chris....he's got to get shape bender working with closed shapes so my life can be easier! While you're at it Chris...a tool to select all faces with the same surface area please. 😄
              Seriously, a 3d texture tool is something I wish for everyday as well, as it would be very useful for my landscape construction modeling.
              I've also been thinking lately it would be nice to have a tool that is a combination of shape bender and profile builder. Something that will draw out repeating components (like brick) and bend them around curves and corners.
              Content Creator at Skapeup
                I could add that to my Selection Toys plugin. All connected faces of the same area or all faces in the currently active entity path?
                • EarthMoverE
                  EarthMover
                  All faces of the same area, connected or disconnected. For example, let's say you had alternating big and little squares and you wanted to select all the big squares at the same time, then use joint push pull, if that makes sense.
                    Makes sense. I'll get around to it.
                      RickW
                      Related to work on ImageProfile2 (oops, spilled the beans), I have deciphered the PNG spec and can now read the PNG image data in Ruby (unfortunately, it is PC only until I also decipher the deflate/inflate algorithm).
                      While that may seem off-topic, it does have a direct correlation - an earlier thread discussed the possibility of a Ruby to create bump maps from SketchUp models (which I'm working on when I can). But it is conceivable that with some work, I could create a Ruby to turn a bump map texture into real geometry, just like this thread requests.
                      RickW
                      www.smustard.com
                        Whaaah? You did? I was looking at the PNG, GIF and JPEG specs when I was making a thumbnail server in PHP once. That was not light material.
                        • Chris FullmerC
                          That's why Rick has been so quiet lately - he's been locked down in his basement for the last 6 months deciphering image formats. Way to go Rick!
                            Did you lock him down there Chris..? o_O Come one be honest now!
                              RickW
                              LOL - you're not too far off. Between heavy (and sometimes overlapping) deadlines at my day job, literally being in my basement deciphering the PNG format (and hopefully soon the inflate/deflate algorithm), and trying not to neglect my family (which will be increasing by one in November), I've been rather quiet here.
                              Oh, and next week, I'll be at the Google I/O conference with Todd. If anyone else is attending, stop by our Developer Sandbox booth and say "hi"!
                              RickW
                              www.smustard.com
                                Congrats man!
                                • Chris FullmerC
                                  You guys are both coming out for that? I was going to sign up but I couldn't find anyone coming out, so I thought I'd pass.
                                  I'll go over and harass the both of you now! Plan on seeing me at some point 😄
                                    Wish I could drop by... 😞
                                    No events ever planned for Europe?
                                      Updated Selection Toys: http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=14975
                                        RickW
                                        @thomthom said:
                                        Congrats man!
                                        Thanks! It was quite unexpected, but also very welcome.
                                        RickW
                                        www.smustard.com
