    New Little Render SU / Maxwell / PS
    21 Posts 14 Posters 2.0k Views 14 Watching
    • FrederikF Offline
      Frederik
      Nice job, mate... Nice job... πŸ‘
      Not sure if it's the tone mapping you've done, but to me it looks a little cold...
      I just tried to play a little with it in Adobe Lightroom... (hope you don't mind...?!?)
      Cheers
      Kim Frederik
        sepo
        Yes I like it a lot. I have suspicion your screen brightness is low. Bit more contrast would certainly make the image to pop out.
        Yeah Frederic that looks better.
        • FrederikF Offline
          Frederik
          That was exactly what I did + cranking up the black a little... πŸ˜‰
          Cheers, Sepo... πŸ‘
          Cheers
          Kim Frederik
          • RichardR Offline
            Richard
            Thanks mate!
            Yeah having trouble matching my laptop screen to my desktop monitor! Then there is the problem that if you raise your eyeline a inch all changes. HP laptops GRRRRR!
            Ooops - updated the image!
            [BUILTBRAND.COM.AU](http://builtbrand.com.au/)
              sepo
              This postprocessing is getting interesting. I would still have more contrast. It seems to me that afternoon sun is low and tops of the trees should be warmer. It would be interesting to hear other people comments as this is really about individual perception. Also hugely depends on monitior calbration or lack of it. I hope Richard would not mind as we all can learn from this.
              • troyhomeT Offline
                troyhome
                Oh I like this one! Man, that grass is real!!! Great shadows on the house- very believable!
                IOviz.com
                SU Pro 2024 PC
                • MarianM Offline
                  Marian
                  WOW this one looks almost real, only that dark brown colour gives it away for me:P
                  • honoluludesktopH Offline
                    honoluludesktop
                    Richard, Very nice render, and I like the symbolism with the entry. Isn't the drinking age liberal in your part of the world? I hope the family has narrow cars πŸ™‚
                    • StinkieS Offline
                      Stinkie
                      Me too! Me too!
                      Sorry, Richard. πŸ˜„
                      • RichardR Offline
                        Richard
                        The grass is actually real! I just inserted a photo of a grass patch post pro!
                          Phil Rader AIA
                          Has this design been built. The gray stucco wing walls on each side of the right garage door seem un-practical. You would not be able to begin maneuvering your car until the front end of your car was clear of those obstructions. They seem to be tight to the garage door so they must only be 8-10 feet apart. I'd be worried that those wing walls would get clipped by a side mirror or something. Nice renders but my functional brain could not let me get past a perceived issue.
                          http://www.philrader.com
                          • brodieB Offline
                            brodie
                            Looks great as usual Richard! Are you planning on doing a night render of this at all? Be interesting to see what it looks like with the lights turned on - especially if it had those small knee level lights near the entry that one of your other houses did.
                            Nice job incorporating the photo images into the rendering.
                            -Brodie
                            • RichardR Offline
                              Richard
                              I've put an update!
                              Don't want to go too dark given that I still need to see the design stand out a bit amongst the veg and shadows! So bit of a balance! So I've played with all elements to get balance right for slightly different lighting.
                              BTW we do have very bright sun here!
                              • olisheaO Offline
                                olishea
                                I cant even tell its a render....truly photorealistic. well done!!
                                oli
                                  cadmunkey
                                  Very nice work Richard.
                                  • Z Offline
                                    zumo
                                    I would be thinking it was a real photo if it was not on this site!
                                    • RichardR Offline
                                      Richard
                                      Thanks guys!
                                      • david57D Offline
                                        david57
                                        Looks very good.
                                        • RichardR Offline
                                          Richard
                                          @david57 said:
                                          Looks very good.
                                          Thanks mate! Update added, much happier now!
