    Checkerboard painting ? (or selection)
    18 Posts 5 Posters 3.4k Views 5 Watching
      todd burch
      Well, it took a few more lines to write than the one line I started with, but it's working. ๐Ÿ‘ See attached pictures.
      Notice the Orange cylinder with the center band that is solid. That is a result of clicking the current selection, which was correctly selected as every other face, with the fill tool. Since Sketchup recognizes the cylinder face as a whole "Surface", (like it might a terrain??), even though every other face that makes up the Surface is selected, whatever band you click on, gets the fill color for the whole band. The faces of the Surfaces that were not clicked fill just fine.
      The purple cylinder example is one in which I picked the colors as part of running the script - they fill just fine.
      The two-tone example was from playing around with it with two colors. Nice Checkerboard, eh?!
      Also note that when a cylinder is checker-boardered, if the # of segments is even, it will work just fine. If odd, the results will be unpredictable.
      I'll get it packaged and uploaded to Smustard sometime tomorrow.
      Todd
        todd burch
        In reference to the even / odd issue, this is what might happen with a 13 sided cylinder.
          Very cool speedy start! ๐Ÿ˜Ž
          Does it be adaptable to this? Thx Zorro2 by Whaat ๐Ÿ˜‰
          (click image for no Scroll bar)
            todd burch
            Yes, it will do non-quadrangular crossed lines, but it won't do faces that don't have 4 sides. For your example, make your starting face much larger than in needs to be, and then use a pattern to get the shape you want. Extrude the pattern, group, move into position, intersect_selected, remove the bits you don't want, and bingo - Happy Valentines day!
            I think I'll put a user interface on it to allow you to pick the color, or colors, and to swap the colors if you don't get the starting square color where you wanted it.
              Bravo! ๐Ÿ‘ And very cool trick for the no four roses faces โ˜€ ๐Ÿ˜Ž
              ๐Ÿ˜Ž
                @ Todd : I am desolated to say that Chris Fulmer had create a ruby script that make exactly that asked at the first post (and more: any selections of form of facets) ๐Ÿ˜„
                I am so sorry for you ๐Ÿ˜‰
                You have shown the way! โ˜€
                  todd burch
                  Good for you and good for him!
                  I'm still working on my user interface.
                  • Chris FullmerC Offline
                    Frenchy, mine doesn't do what Todd's does. Mine just randomly applies pre-selected color. Todd's makes a checkerboard like you asked for. I was making one for Equadorian who asked to have per-selected colors applied randomly to selected faces. So while they are similar, they are different. And I'm sure Todd's is going to be much more user friendly, and his menu probably won't end up in a never ending loop like mine likes to ๐Ÿ˜„
                      Ok I understand you pick facets in any order! ๐Ÿ˜ณ ๐Ÿ˜ฎ ๐Ÿ˜’ ๐Ÿ˜†
                      It's a pity ๐Ÿ˜‰
                      So you are both winners โ˜€
                        AcesHigh
                        where is the download link? ๐Ÿ˜ž
                          Not yet released but you can try this one ๐Ÿ˜‰
                            AcesHigh
                            lol, come on, it was already said that Random Painter isnt able to create a checkbox pattern, since, of course, its randon ๐Ÿ˜„
