    Some new Renders..
    73 Posts 46 Posters 22.4k Views 46 Watching
    • C
      Crazy Eyes
      Just a kinda unrelated question.
      Are you self taught in SU and v-ray?
      I want to improve my skill level and want to know how to go about doing that.
      Cheers
      Some people are lovers, some are fighters, if you love to fight, fight for love!
        silver_shadow
        I am doing now su for 4 years and vray for about 2 years. Self taught. Me and Free agent used to work together and we helped each other to get into sketchup and vray. Sketchup is easy to learn and a lot of plugins helps you to do better models in quicker time. Thats what makes su so great. Vray is kind of a steep learning curve, but once you kinda know how to use it, you can use it in other platforms too. The interface is the same in other applications. So its a good thing to learn it. You can contact me if you need help, and ill help and support where i can. In modeling or in vray.
          jds
          amazing work from the capetown guys!!! love it
          you and free agent always amaze me with your renders bravo!!! 👍 👍
          • C
            cadmunkey
            Excellent modelling and images, congrats sir!
            • L
              lucifer1101
              That is spectacular architecture, where do you get your ideas from?
              Some of my 3d
                silver_shadow
                we entered a competition but did not get it, pitty...it would have been interesting to see it go up.
                The bungalow is still happening tho
                • free agentF
                  free agent
                  crap u didnt get it, such an awesome presentation, u should post a small version of that Sheet that was put together for it.
                  http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
                    silver_shadow
                    here you go
                    http://www.box.net/shared/et4thifcba
                    12 panel each one is a A1 sheet.So the presentation was quite a huge board
                      21D
                      @silver_shadow said:
                      here you go
                      Hi there Silver,
                      nice too see you again....and really great stuff you got there...
                      one Q though, which software did you use for the PLANS??? they look amazing
                      "I prefer drawing to talking. Drawing is faster, and leaves less room for lies."
                      Le Corbusier
                        silver_shadow
                        The plans were done in Vectorworks, exported to pdf, and imported to photoshop cs2
                        The elevations were done in Su, rendered in Vray and touched up in cs2
                        Sections were first made from su, brought into vectorworks for cleanup and then pdf and cs2
                        But final composition were made in Photoshop. Glad you like it
                        • free agentF
                          free agent
                          hehe now go ask them for permission to share it 😉
                          • N
                            nomeradona
                            excellent render. one of the best render ive seen with vray su.
                              silver_shadow
                              Hey nomeradona, congrats on your prize on podium!!
                                21D
                                SO as a vectorworks user, do you recomend a AutoCAD user to switch or use both??
                                because i've seen some great work (PLANS) done by Vectorworks...and yours makes me want to learn this software even more, and also to improve my presentations.
                                Le Corbusier
                                  silver_shadow
                                  Well i must say..i like vetorworks a bit more than autocad. But it comes down to user preferences.
                                  You can draw just a sfast as you can in autocad if you get to know it better and set up some basic shortcuts, and it also do have a 3d package in it, really bad, but overall i like it. worth while learning it.
                                  It has got layers, classes and saved sheets. Layers you can group all your pens which is switched on and off into layers and have them as groups switched on or off. It has got viewports also. Further on on the new vectorworks 2008 you have pens and fills you can make transparent, like if you want to make glass, draw in a class you set up called glass and give it transparency like su and it will show it like that in cad, anything behind it will still show depending on transparency.So id say its not a bad program to learn and also quite easy to learn it too. If you walk into a firm not knowing vworks, ill bet you you will be running the program by the end of the week, if no one really helps you.
                                  • chavinskeeC
                                    chavinskee
                                    here you go
                                    w 😮 w! superb images! how did you render the elevations in vfsu?
                                    http://chavinskee.blogspot.com/
                                      silver_shadow
                                      here you go
                                      you choose an elevation in sketchup, no perspective..set up the shadows and make sure you got the new vray installed and render it using the default camera 😉
                                      • daleD
                                        dale
                                        Always a pleasure to see your work. I use Vectorworks as well as Acad, but I prefer VW, but agree that it is users choice. Before SketchUp I used to do all my 3D stuff in VW. Way more complicated to do, but got pretty good final results.
                                        Anyway, Love your work.
                                          21D
                                          thnx for the advice mate, i will definitly try it out.
                                          Le Corbusier
                                          • K
                                            kwistenbiebel
                                            Really great work there Silver! 👍
                                            You have been busy.
                                            and yeah, vectorworks is more like drawing on a drawing board. it has a bit more of a graphical approach instead of the technical approach of Autocad, at least that is how I use it (I never touch the BIM module).
                                            On the other hand, it seems that both Vectorworks as Autocad will be obsolete...as Revit seems to be taking over drafting (and documenting) in arch firms nowadays.
                                            • 1 / 4
