    Some new Renders..
    73 Posts 46 Posters 20.6k Views 46 Watching
      21D
      @silver_shadow said:
      here you go
      http://www.box.net/shared/et4thifcba
      12 panel each one is a A1 sheet.So the presentation was quite a huge board
      Hi there Silver,
      nice too see you again....and really great stuff you got there...
      one Q though, which software did you use for the PLANS??? they look amazing
      "I prefer drawing to talking. Drawing is faster, and leaves less room for lies."
      Le Corbusier
        silver_shadow
        The plans were done in Vectorworks, exported to pdf, and imported to photoshop cs2
        The elevations were done in Su, rendered in Vray and touched up in cs2
        Sections were first made from su, brought into vectorworks for cleanup and then pdf and cs2
        But final composition were made in Photoshop. Glad you like it
        • free agentF
          free agent
          hehe now go ask them for permission to share it 😉
          http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
          • N
            nomeradona
            excellent render. one of the best render ive seen with vray su.
              silver_shadow
              Hey nomeradona, congrats on your prize on podium!!
                21D
                SO as a vectorworks user, do you recomend a AutoCAD user to switch or use both??
                because i've seen some great work (PLANS) done by Vectorworks...and yours makes me want to learn this software even more, and also to improve my presentations.
                Le Corbusier
                  silver_shadow
                  Well i must say..i like vetorworks a bit more than autocad. But it comes down to user preferences.
                  You can draw just a sfast as you can in autocad if you get to know it better and set up some basic shortcuts, and it also do have a 3d package in it, really bad, but overall i like it. worth while learning it.
                  It has got layers, classes and saved sheets. Layers you can group all your pens which is switched on and off into layers and have them as groups switched on or off. It has got viewports also. Further on on the new vectorworks 2008 you have pens and fills you can make transparent, like if you want to make glass, draw in a class you set up called glass and give it transparency like su and it will show it like that in cad, anything behind it will still show depending on transparency.So id say its not a bad program to learn and also quite easy to learn it too. If you walk into a firm not knowing vworks, ill bet you you will be running the program by the end of the week, if no one really helps you.
                  • chavinskeeC
                    chavinskee
                    here you go
                    w 😮 w! superb images! how did you render the elevations in vfsu?
                    http://chavinskee.blogspot.com/
                      silver_shadow
                      here you go
                      you choose an elevation in sketchup, no perspective..set up the shadows and make sure you got the new vray installed and render it using the default camera 😉
                      • daleD
                        dale
                        Always a pleasure to see your work. I use Vectorworks as well as Acad, but I prefer VW, but agree that it is users choice. Before SketchUp I used to do all my 3D stuff in VW. Way more complicated to do, but got pretty good final results.
                        Anyway, Love your work.
                          21D
                          thnx for the advice mate, i will definitly try it out.
                          Le Corbusier
                          • K
                            kwistenbiebel
                            Really great work there Silver! 👍
                            You have been busy.
                            and yeah, vectorworks is more like drawing on a drawing board. it has a bit more of a graphical approach instead of the technical approach of Autocad, at least that is how I use it (I never touch the BIM module).
                            On the other hand, it seems that both Vectorworks as Autocad will be obsolete...as Revit seems to be taking over drafting (and documenting) in arch firms nowadays.
                            • T
                              teofas
                              ive always admire your modeling and render skills, i think this are great examples of the great things SU can do, very inspiring bro! 👍
                              http://www.spazioarquitectura.com
                              • boofredlayB
                                boofredlay
                                Wow, this is great work. I am taking notes...
                                  mateo soletic
                                  Amazing work Jacques. 👍
                                  Anything less from you and we would be disappointed.
                                  And BTW thats a great board. 👍
                                  Concept Illustrations
                                  • G
                                    goutham
                                    mastery work......i am a beginner in v ray ..its a great inspiration..
                                    thank you. 👍
                                      stereofidelic
                                      wow 👍
                                      • utilerU
                                        utiler
                                        @crazy eyes said:
                                        Just a kinda unrelated question.
                                        Are you self taught in SU and v-ray?
                                        I want to improve my skill level and want to know how to go about doing that.
                                        Cheers
                                        I'm with crazy eyes..... 😲
                                        Just Curious...
                                        • utilerU
                                          utiler
                                          I am doing now su for 4 years and vray for about 2 years. Self taught. Me and Free agent used to work together and we helped each other to get into sketchup and vray. Sketchup is easy to learn and a lot of plugins helps you to do better models in quicker time. Thats what makes su so great. Vray is kind of a steep learning curve, but once you kinda know how to use it, you can use it in other platforms too. The interface is the same in other applications. So its a good thing to learn it. You can contact me if you need help, and ill help and support where i can. In modeling or in vray.
                                          Gee that is a generous offer, Jacques. I might even do that..... 😄
                                          Just Curious...
                                          • utilerU
                                            utiler
                                            By the way, georgous kid, Free Agent!!! reminds me of my little angel a few years ago... [yes, with the cow in the back ground as well!!!]
                                            Just Curious...
                                            • 2 / 4
