    Add DC-Attribut to group not show up
    4 Posts 2 Posters 244 Views 2 Watching
    • H Offline
      HPW
      I generate groups for my imported autocad-components to restore a hierachy.
      Now I would like to show some info in the 'Components Options' window when group is clicked.
      First I follow TIG's hint and add a definition to the group:
      class Sketchup;;Group
        def definition
          return self.entities[0].parent
      Then I do:
      ### Creating of the group from array
         group = entities.add_group(@group_list)
      ### Try to store attribut in group
         group_def = group.definition
         group_def.set_attribute 'dynamic_attributes', '_hasbehaviors', '1.0'
         group_def.set_attribute 'dynamic_attributes', '01_dummy', 'Dummy'
         group_def.set_attribute 'dynamic_attributes', '_01_dummy_label', '01_dummy'
         group_def.set_attribute 'dynamic_attributes', '_01_dummy_formlabel', 'This is a dummy attribute'
         group_def.set_attribute 'dynamic_attributes', '_01_dummy_units', 'STRING'
         group_def.set_attribute 'dynamic_attributes', '_01_dummy_access', 'VIEW'
         group_def.set_attribute 'dynamic_attributes', 'name', 'MyName'
         group_def.set_attribute 'dynamic_attributes', 'description', 'MyDescription'
         group_def.set_attribute 'dynamic_attributes', 'dialogwidth', '460'
         group_def.set_attribute 'dynamic_attributes', 'dialogheight', '550'
      The attribute gets stored in the dictionary, but opening the 'Components Options' window show only the default window with group.name and 'There are no options to choose on this component.'
      Maybe it is hardcoded that group can not have DC attributes?
        A Group can have attributes. A Component Definition OR Instance can too. However a Group is a special case. It has a definition BUT normally there should only ever be one instance of it - which is the group. A Group's definition is not normally used - however it is a way of moving a group into another group to avoid crashes. A Group is not acomponent so the Components Option window will not report its definition attributes.
        Solution: add the attributes to the Group itself and 'make_unique' to ensure that there are no duplicate instances of it. There shouldn't be... but a known bug means there can be... For example, using Ruby make a group of some geometry, copy the group, delete an edge in the copy and it'll sometimes also disappear in the original as if it were a component. Using make_unique on the copy returns a 'deprecated method' warning, BUT it works and groups are thereafter kept as individuals. If you copy a group within SUp then it is automatically made_unique. If you copy a group with Ruby and edit the contents of the copy manually the original is also made unique by that action... Just sometimes Ruby-copied groups are read as dupliactes of the same definition - which they should never be...
        Weird...
        • H Offline
          HPW
          TIG,
          Many thanks again for this tip.
          Since my groups are unique I tried to attach to the group itself.
          And it works!
          By the way: The make_unique throws a warning that it is depreciated.
          One problem pops up.
          The little image in the top left edge of the 'Components Options' window show normaly the component.
          Since the Group itself is no component it shows the last successfull loading image.
          I tried to set:
             group.set_attribute 'dynamic_attributes', 'imageurl', ''
          but this does not help.
          Not sure if I must point to a real image on the net or can I use a local file-url.
          Hans-Peter
            Unfortunately, as you say, a group is not a component !
            The group.make_unique is 'deprecated' BUT it works till it's fixed by Google...
            Why don't you make the group into a component, THEN you can probably use it as desired - inst=group.to_component - returns its instance OR defn=group.to_component.definition - returns its definition if you want to add to that... OR instn=defn.instances[0]to return what you just 'componentified' from the group...
