    Call to Mac users for script portability
    101 Posts 10 Posters 19.1k Views 10 Watching
    • jeff hammondJ
      where's the newest update posted at?
      • fredo6F
        Jeff, Bob,
        This was just a trial on one button type, but it happens to work!
        Could you try with with new update, which should hopefully show all button images.
        to drop into LIBFREDO6_Dir_31 folder
        • fredo6F
          Jeff
          You've too quick. The Forum went down for me a few minutes. I was updating the update to also include a change for the 'Hand'.
          • jeff hammondJ
            haha.. sorry.
            so the latest one is:
            no icons at all.
            the hand appears when hovering over the 'select all' and 'clear all' boxes but not with the factories.
            • fredo6F
              I made a mistake. this one should be better, hopefully
              Thanks for the 'hand'
              • jeff hammondJ
                BINGO!
                all icons are showing and working... the hand shows up when hovering over all icons..
                nice work fredo.
                everything else looks good too (size of the dialog box, title showing, cancel-reset-save buttons are visible, colors work, function keys work, etc.)
                as far as i can tell, it's fully mac ready.
                thanks so much!
                • Bob JamesB
                  Bob James
                  Ditto πŸ‘
                  Sorry it took so long: My wife had some "other things" for me to do.
                    driven
                    Mac user returning to SU (haven't really use since @last stopped sending me free pro licenses... a while ago
                    Trying to add all the things that use to drive me mad and putting them in the right place seems to be an issue, I'm having no joy getting this to work.
                    It is on SU, the two buttons are there and dim when clicked, but there's no tool or functionality change.
                    Can someone out there post a screenshot or video of a working setup.
                    I have found some of the other scrips worked after moving bits downstream.
                    cheers in advance
                    This is where it's not working from on mine
                    john (OSX 10.5.6 2.8 core2 duo + macbookPro,)
                    • jeff hammondJ
                      hey john
                      you have everything in the right place but that's the old freescale ver1
                      you might want to try version 2 to see if things go more smoothly.
                      here are the direct links to the downloads:
                      [freescale_20e]
                      http://www.sketchucation.com/forums/scf/download/file.php?id=26091
                      [libfredo6_31e]
                      http://www.sketchucation.com/forums/scf/download/file.php?id=26089
                      i think your problem might be that you're using an older version of freescale with a newer library...
                      remove the following 5 items from your SU plugins folder:
                      %(#FF0000)[FREESCALE_Dir_10
                      LIBFREDO6_Dir_31
                      LibFredo6.rb
                      ZLoader__FreeScale.rb
                      DEFPARAM_Dir]
                      then, add the items to your SUplugins folder from the links i gave above which will be:
                      %(#0000BF)[FREESCALE_Dir_20
                      LIBFREDO6_Dir_31
                      LibFredo6.rb
                      DEFPARAM_Dir]
                      this will assure you have the latest version and files that are compatible with each other(version 2e)
                      • fredo6F
                        BINGO!
                        nice work fredo.
                        thanks so much!
                        Jeff,
                        Thanks for your support.
                        I still need to find a way to control the height of table rows, but that's more to do with Safari browser. So I may need some extra support in the coming days.
                        • fredo6F
                          Problem about padding in table rows
                          Here is an update to check if I can get control of the table rows margins on Mac. This only impacts the Default Parameters Dialog boxes.
                          Thanks to advise
                          • jeff hammondJ
                            i'm not sure what the table row margins are but as far as i can tell, the only difference with the latest file is that it adds something weird to sketchup in general..
                            that little square isn't part of the icon.. it's just floating on top (i can move the toolbar and the square will remain).. that's what the bottom-right corner of a window in os x looks like and it's used for resizing the window.
                            • fredo6F
                              Jeff
                              Did you notice the little sqare with the previous version (I mean the one fixing the button image)?
                              for the row heights, they should normally be smaller (as they are on Windows). At least, this is the intent!
                              Fred
                              PS: the very first time you call a web dialog (Translation or default parameters), I open and close an empty web dialog in order to determine some parameters of the browser, such as the version, the screen size, etc...). You should normally see this event.
                              • jeff hammondJ
                                Jeff
                                my bad.. i think that was being caused by a screencapture app i'm demoing (the one i used to make the red arrow in the previous post πŸ˜„)...
                                the row heights appear the same though:
                                (that's scrolled down a little to show all the icons)
                                ah, i see.. it's not a problem at all with the way they are sized now but maybe your attention to detail is greater than mine πŸ˜„
                                yeah, i see that.. a fast flash of a blank window prior to the freescale dialog popping up..
                                • jeff hammondJ
                                  hmm.. nope it's the latest config file causing it.
                                  i closed everything except sketchup and the little square pops up right after i open the freescale parameters.
                                  [edit] and upon reverting to the original config file (the one in version e), i get the same thing so it's not the cause..
                                  i'll try to go back through some of the other files to see which update it starts with.
                                  • fredo6F
                                    Jeff,
                                    Don't spend your time finding out. It is very plausible that it related to SU Web dialogs, where the modal mode for Web dialogs does not really exist on Mac. So LibFredo6's fault.
                                    Can you try the attached file and watch:
                                    • the little square
                                    • the row heights
                                    to drop into LIBFREDO6_DIR_31 folder
                                    • jeff hammondJ
                                      looking good..
                                      no little square and the rows are smaller
                                      • fredo6F
                                        Jeff,
                                        Thanks. That was the reason for the small square. You're the first one to notice.
                                        For row heights, it seems I have also found the subtilities for Safari (which behaves very differently from IE).
                                        Could you make a try with the 2 attached files on:
                                        • the Default Parameter dialog boxes
                                        • The translation boxes
                                        • the language definition dialog box (within the translation dialog box, select 'New language' in the combo box at the top left).
                                        • jeff hammondJ
                                          these ones make the row spacing big again in the default parameters.
                                          i haven't opened the language boxes lately but they're looking like the original parameters windows.
                                          this is how they look with the new and old files..
                                          • fredo6F
                                            Well, this means that Safari definitely takes some freedom with the W3C specifications.
                                            Can you try this one then?
                                            • 4 / 6
