    Bugsplat+ distortioned images
    6 Posts 2 Posters 1.2k Views 2 Watching
      arquimenez
      http://img134.imageshack.us/img134/1663/edif2.jpg doe anyone have the same problem? it happens when i use some command or open the start button
      • soloS
        That's 100% your video card issue.
        Try unselecting the AA and unselect and select 'use fast feedback', if all fails try unselecting the 'use hardware acceleration' option.
        What card is it?
        Get the new updated drivers from the manufacturers site.
          arquimenez
          thanks a lot for your quick help solo! sorry for my ignorance, but what does aa mean? and i'm using a nvidia Geforce 8400
          • soloS
            http://img142.imageshack.us/img142/6119/image1yam.jpg
            Set it to zero, I have mine at 4x
            Your card should work fine, there are new drivers (feb) that are very stable.
              arquimenez
              i'm dowloading now the new drivers, i'm gonna see if that helps me right now, thanks a lot solo! another question, when my model is quite large, with a lot of detail, it is normal that takes a wile for the computer to change from sketch to another software and from another software to my model? and importing some plans from autocad i got bugsplat, and the plans are not really big
              • soloS
                Unfortunately Sketchup does not handle large models very well so switching between apps will require SU to 'reload' the scene which will take a while especially with shadows on.
                I cannot respond much about importing your CAD plans (assume ,dwg) as I do not know if you imprted it in the beginning or after you already had a large model, which would explain it if indeed it was the latter.
