    How do you make plug-ins for sketchup
    103 Posts 25 Posters 18.2k Views 25 Watching
    • B
      BTM
      That's good, but my main issue (which I've been trying to figure out) is how to use the cursor to set the transformation, like the move tool does; click and drag. I thought I saw something on it once, but am still confused.
      *I started writing this before remus's post. I see you used the 'selection' method, I guess that would fix the whole pushpull-resulting-faces issue I had.(that's what they're called, methods, right? I can never remember...)
      *I started that last part before Chris posted πŸ˜’ and Chris, why won't it work to just replace e.pushpull 10 with e.clear! ?
      • B
        BTM
        ...but I DID manage to get it to reverse faces πŸ˜‰
        model = Sketchup.active_model
        selection = model.active_entities
           selection.each { |entity|
              if entity.typename == "Face"
              entity.reverse!
        Why does reverse! work, but not clear! ?
          remus
          give em some credit chris, i had to type 'selection' as well πŸ˜„
          • Chris FullmerC
            πŸ˜„
            .clear! will empty an array, it does not erase anyhing from the model. Glad you found the erase! method.
            You can also go through and put everything to erase into an array of entities, then use
            entities.erase_entities my_array_of_entities
            to delete them all in one shot. Apparently some people have ran into bugsplats when erasing entities one at a time like you've done in your example.
            • B
              BTM
              ...Nevermind. I found in the parent directory; erase! 🀣( How didn't I notice that?)
              entity.erase!
              • Chris FullmerC
                Heh, I didn't notice that you switched it around to use the selection set instead of all entities. Well done πŸ˜„ Now make it smart enough to use the selection set if it exists, and if not, use all entities.
                • B
                  BTM
                  It probably got overrun by new posts, so here's my original question about translation
                  Your last post, Chris: Ah, and that's easy.
                  if model.selection == true
                  selection = model.selection
                  else
                  entity.erase!
                  ...well, sort of easy. It seems to be buggy, and deletes random faces, if anything is selected. πŸ˜•
                  How do you put all the entities into an array again?
                    remus
                    just learnt an important lesson about using recursion in combination with a messagebox.
                    entities = model.selection
                    entities.each { |e|
                     if e.typename == "Curve"
                     edgnum = e.count_edges
                     UI.messagebox "edgnum.to_s"
                     else
                     UI.messagebox "Please select a curve"
                    10 points if you can spot what'll happen (without running it!)
                    • B
                      BTM
                      it counts the edges of any selected curve, and displays them as a string, in a message box. If 20 curves were selected, then 20 different message boxes, with the amount of edges in each curve, is shown, one after another each time you click enter. πŸ˜‰
                        remus
                        Could well do, but it's worse than that...points still up for grabs.
                          remus
                          Close enough, it will keep saying 'please select a curve' until you force quite SU, as it keeps going through the model.
                          • B
                            BTM
                            oh, I forgot to mention that if no curve is selected, it says the message "Please select a curve".
                            Oh, and I'm pretty sure you wrote part of your code wrong, which could cause... hmmm.... I don't know... O.K., I'm testing it πŸ˜‰
                            • B
                              BTM
                              No, just tested it, I think it says it once for every edge in the selected curve/curves.
                                remus
                                thats interesting, more experimenting is needed!
                                edit: perhaps in the morning. Its getting a bit late now πŸ˜‰
                                • B
                                  BTM
                                        UI.openURL "http://www.sketchucation.com/forums/scf/"
                                  πŸ˜‰
                                  • Chris FullmerC
                                    Well, this is not the problem in question, but a selection will not contain an entity "Curve" for one thing. It contains edges though, and they might belong to a curve. So you can test if e.typename == "Edge" and then if true test if e.curve != false.
                                    (And this gets back to what Adam was bringing up and Jim also talked about in another post. I think instead of testing if each entity is an edge (which is how I still do it), perhaps test each entity if its part of a curve. (I don't know the best code to do that, but its something to think about).)
                                    I think that a selection can only hold DrawingElements (which does not include curves). I'm not sure why though.
                                    • B
                                      BTM
                                      • Chris FullmerC
                                        Oh, and BTM, in my opinion, as a fairly new Ruby scripter, making any script that interacts with the mouse is a bit challenging, especially at first. It requires making a class tool, and instantiating the tool, and making good use of methods, including pre-defined methods from the API. I'll try to write up a template for creating a new tool. But that is really a tutorial all of its own. (BTW, I said before I was working on a tutorial for beginning ruby, and its been put on hold because the methods for wiritng a tutorial for SketchUcation are currently not working....so I have to wait for the management to fix it.)
                                        If possible, I would avoid the mouse controlling the transform idea.
                                        • Chris FullmerC
                                          To be more specific, I don't understand how to implement the inferencing system of SU. I have a sfew scripts that use inferencing, but I literally copied and pasted portions of those scripts from the query tool example that comes with SU. If you want to being working with inferencing, check out that tool.
                                            Jim
                                            @adamb said:
                                            [Slightly OT]
                                            I've always been very careful to use Object#kind_of? rather than Object#class so that code works with any derived classes too. (Rather than just testing for an explicit class).
                                            Good idea? Bad idea?
                                            Adam
                                            It's good when you explode a Group to reject things are not Drawinglements. Sometimes I get Loops in the exploded collection of entities.
                                            ents = group.explode
                                            ents.reject!{ |e| unless e.is_a? Sketchup;;Drawingelement }
                                            • 4 / 6
