    How do you make plug-ins for sketchup
    103 Posts 25 Posters 20.3k Views 25 Watching
      remus
      A complete rip off of BTMs code:
      model = Sketchup.active_model
      entities = model.selection
      entities.each { |e|
         if e.typename == "Face"
         e.pushpull 10
      • Chris FullmerC
        then change it around and make it erase all faces instead of pushpulling them πŸ˜„
        Edit: you literally just copied and pasted, awesome!
        • B
          BTM
          That's good, but my main issue (which I've been trying to figure out) is how to use the cursor to set the transformation, like the move tool does; click and drag. I thought I saw something on it once, but am still confused.
          *I started writing this before remus's post. I see you used the 'selection' method, I guess that would fix the whole pushpull-resulting-faces issue I had.(that's what they're called, methods, right? I can never remember...)
          *I started that last part before Chris posted πŸ˜’ and Chris, why won't it work to just replace e.pushpull 10 with e.clear! ?
          • B
            BTM
            ...but I DID manage to get it to reverse faces πŸ˜‰
            selection = model.active_entities
               selection.each { |entity|
                  if entity.typename == "Face"
                  entity.reverse!
            Why does reverse! work, but not clear! ?
              remus
              give em some credit chris, i had to type 'selection' as well πŸ˜„
              • Chris FullmerC
                πŸ˜„
                .clear! will empty an array, it does not erase anyhing from the model. Glad you found the erase! method.
                You can also go through and put everything to erase into an array of entities, then use
                entities.erase_entities my_array_of_entities
                to delete them all in one shot. Apparently some people have ran into bugsplats when erasing entities one at a time like you've done in your example.
                • B
                  BTM
                  ...Nevermind. I found in the parent directory; erase! 🀣( How didn't I notice that?)
                  entity.erase!
                  • Chris FullmerC
                    Heh, I didn't notice that you switched it around to use the selection set instead of all entities. Well done πŸ˜„ Now make it smart enough to use the selection set if it exists, and if not, use all entities.
                    • B
                      BTM
                      It probably got overrun by new posts, so here's my original question about translation
                      Your last post, Chris: Ah, and that's easy.
                      if model.selection == true
                      selection = model.selection
                      else
                      entity.erase!
                      ...well, sort of easy. It seems to be buggy, and deletes random faces, if anything is selected. πŸ˜•
                      How do you put all the entities into an array again?
                        remus
                        just learnt an important lesson about using recursion in combination with a messagebox.
                        entities.each { |e|
                         if e.typename == "Curve"
                         edgnum = e.count_edges
                         UI.messagebox "edgnum.to_s"
                         else
                         UI.messagebox "Please select a curve"
                        10 points if you can spot what'll happen (without running it!)
                        • B
                          BTM
                          it counts the edges of any selected curve, and displays them as a string, in a message box. If 20 curves were selected, then 20 different message boxes, with the amount of edges in each curve, is shown, one after another each time you click enter. πŸ˜‰
                            remus
                            Could well do, but it's worse than that...points still up for grabs.
                              remus
                              Close enough, it will keep saying 'please select a curve' until you force quite SU, as it keeps going through the model.
                              • B
                                BTM
                                oh, I forgot to mention that if no curve is selected, it says the message "Please select a curve".
                                Oh, and I'm pretty sure you wrote part of your code wrong, which could cause... hmmm.... I don't know... O.K., I'm testing it πŸ˜‰
                                • B
                                  BTM
                                  No, just tested it, I think it says it once for every edge in the selected curve/curves.
                                    remus
                                    thats interesting, more experimenting is needed!
                                    edit: perhaps in the morning. Its getting a bit late now πŸ˜‰
                                    • B
                                      BTM
                                            UI.openURL "http://www.sketchucation.com/forums/scf/"
                                      πŸ˜‰
                                      • Chris FullmerC
                                        Well, this is not the problem in question, but a selection will not contain an entity "Curve" for one thing. It contains edges though, and they might belong to a curve. So you can test if e.typename == "Edge" and then if true test if e.curve != false.
                                        (And this gets back to what Adam was bringing up and Jim also talked about in another post. I think instead of testing if each entity is an edge (which is how I still do it), perhaps test each entity if its part of a curve. (I don't know the best code to do that, but its something to think about).)
                                        I think that a selection can only hold DrawingElements (which does not include curves). I'm not sure why though.
                                        • B
                                          BTM
                                          • Chris FullmerC
                                            Oh, and BTM, in my opinion, as a fairly new Ruby scripter, making any script that interacts with the mouse is a bit challenging, especially at first. It requires making a class tool, and instantiating the tool, and making good use of methods, including pre-defined methods from the API. I'll try to write up a template for creating a new tool. But that is really a tutorial all of its own. (BTW, I said before I was working on a tutorial for beginning ruby, and its been put on hold because the methods for wiritng a tutorial for SketchUcation are currently not working....so I have to wait for the management to fix it.)
                                            If possible, I would avoid the mouse controlling the transform idea.
                                            • 4 / 6
