    Multipe surface select
    5 Posts 3 Posters 453 Views 3 Watching
      shape
      I know using the eraser and hitting the space bar could select multiple edge/line at one go but it cannot select from multiple location crossing unwanted ones. Is there a way to multiple select surfaces like eraser on lines from multiple location and crossing unwanted ones?
      • Chris FullmerC
        Are you asking if there is a way to use the eraser tool where you can select certain lines, but skip over other lines?
          Seems don't work! ๐Ÿ˜ฎ
          It's Shift + Eraser but you must pass over with mouse! So invert Selection if you want faces ๐Ÿ˜‰
          It is triple CLICK for select face + lines ! ๐Ÿ˜‰
          SHIF + CTRL = Deselect from a multiple selection
            shape
            • yes
            Pilou- i use the eraser, holding click to select and then press the space bar after selecting. While still holding on the space bar i will release click and this will leave those i wanted selected. But i am not able to skip over unwanted lines and continue selecting. And what i am hoping is to select surfaces(most importantly) and lines too skipping over unwanted surfaces/lines. Hope i can be clear this time ๐Ÿ’š
              Ah OK ๐Ÿ˜„
              I believe that exist a plug that select with the mouse like the "eraser method" maybe by TIG or WHAAT....
              maybe this can help you ๐Ÿ˜‰
